2-wheel or 4-wheel-ABS
Old 01-11-2011, 03:30 AM
Rik's Avatar
Rik
Rik is offline
Default 2-wheel or 4-wheel-ABS
Hi Folks!
can you say me, if my truck has a 2- or 4-wheel-ABS?
itīs a RAM2500, 4x4, HD from '03/'04
When i brakes on snow and ice, i see in the mirrow, that the rear-Wheels blocked and only the front wheels are braking with ABS...
thx,
Rik
Old 01-11-2011, 07:07 AM
MikeHTally's Avatar
MikeHTally
MikeHTally is offline
If you have two-wheel, it'll be on the rear wheels only. Four-wheel will include the front wheels. Two-wheel will allow the fronts to lock first.
Old 01-11-2011, 07:55 AM
bwdakrt's Avatar
bwdakrt
bwdakrt is offline
I do believe you have 4wabs. The abs controller has the 2 connector plugs and 4 lines going out. At least that's the same controller on my RT and I have 4wabs.
Old 01-11-2011, 07:58 AM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
Taking a picture of the ABS module wont tell me anything but if you need to know for sure, get under the truck and look at the spindles and there would be a wire coming out of the wheel bearing hub. That wire is the ABS sensor in the hub assembly.
Here is a stock photo
Quick Reply: 2-wheel or 4-wheel-ABS
