Transmission Fluid Capacity
Old 01-07-2011, 02:49 PM
mjonesjr's Avatar
mjonesjr
mjonesjr is offline
Default Transmission Fluid Capacity
I have a '96 1500 with the 5.9. I am going to drop the pan tomorrow and change the transmission fluid.
I have the stock pan, how many quarts of ATF+4 will I need to fill it back up with?
Old 01-07-2011, 03:08 PM
ferguson30's Avatar
ferguson30
ferguson30 is offline
Last time I did mine it took right at 5 quarts.
Old 01-07-2011, 03:13 PM
PurplDodge's Avatar
PurplDodge
PurplDodge is offline
Depends on how much comes out and how long you let it sit. Best way to find out is to measure how much comes out.
Old 01-07-2011, 03:20 PM
TwistedCage's Avatar
TwistedCage
TwistedCage is offline
calls for 4 qts to drain and fill 11 or so to dry fill
Old 01-07-2011, 07:32 PM
dipsherry's Avatar
dipsherry
dipsherry is offline
just did mine yesterday and let it sit for around a half hour with no pan on it took me 6 quarts and a quart of lucas so 7 quarts i wanted to drain as much as possible thats y i let it sit for so long
Thomas oi812 (07-11-2021)
Old 01-07-2011, 07:49 PM
PurplDodge's Avatar
PurplDodge
Dont use lucas.
Also dont forget to put in a drain plug!
Old 01-07-2011, 10:36 PM
jasonw's Avatar
jasonw
jasonw is offline
Site Moderator
+1 for no Lucas. Been known to ruin our picky transmissions. Pure ATF+4 only.
Old 01-07-2011, 10:40 PM
grox's Avatar
grox
grox is offline
It takes 4 quarts.
Old 01-07-2011, 11:39 PM
matty675's Avatar
matty675
matty675 is offline
mine took 8
Old 01-08-2011, 12:55 AM
Sheriff420's Avatar
Sheriff420
Sheriff420 is offline
It takes 4-8.
Like Purpl said, it depends on how long you let it sit.
I let mine sit overnight the last time I changed it and it took close to 8 quarts.
I think it took 6 the time before that.
Quick Reply: Transmission Fluid Capacity
