Vehicle Theft Security System won't turn off
Old 01-06-2011, 05:34 PM
White Buffalo's Avatar
White Buffalo
White Buffalo is offline
Default Vehicle Theft Security System won't turn off
I have a 1998 Durango SLT with a 5.9. Quite a while back the key fob quit working (no not the battery) but no big deal I just used the key. When you use the power locks to lock the vehicle when leaving it arms the security system and when you use the key to unlock your door it is supposed to disarm the security system. My problem is the key will not disarm the security system and the lights blink and horn beeps and the vehicle won't start as a result. Any thoughts or suggestions would be appreciated.
Old 01-06-2011, 06:30 PM
WhiteWidow00's Avatar
WhiteWidow00
WhiteWidow00 is offline
The key does no disarm the system. Only the fob will disarm the system. If you don't want the system armed, simply lock the doors manually.
Old 01-06-2011, 06:52 PM
shrpshtr325's Avatar
shrpshtr325
shrpshtr325 is offline
THE ULTI-MOD
yea what whitewidow said, to my knowledge (im not perfect) the only way to disarm the alarm is to use the remote,
when your remote stopped working, did you notice any other (probably seem unrelated) electrical problems crop up???
Old 01-06-2011, 07:03 PM
White Buffalo
The key does disarm the security system, I have been doing it for months. If I unlock the door (after using the power locks to lock the vehicle) from an open window by pulling up the lock manually the alarm would go off after opening the door and I would have to use the key to turn it off. I have not noticed any other electrical problems. I tried disconnecting the battery today hoping it would reset somehow but that did not work
Old 01-06-2011, 11:16 PM
hydrashocker's Avatar
hydrashocker
hydrashocker is offline
You can dis-arm the OEM security system by using the main key in the drivers door.
You might need to reset the OEM alarm: https://dodgeforum.com/forum/1st-gen...going-off.html
Old 01-07-2011, 05:19 PM
White Buffalo
Unfortunately the reset procedure did not work. When this problem started my driver door was frozen and I had to use a lighter on the key to unfreeze the "key hole" to unlock the door. I am going to get the vehicle into the garage and warm it up hoping something is frozen (yea, fat chance) and try again.
Old 03-11-2011, 07:19 AM
White Buffalo
I finally broke down and took the truck to the dealer . It turned out to be a wiring problem with the security system. "Only" cost me 300 bucks (not bad considering I was thinking worse) and am on the road again. Thanks for the help.
Old 06-27-2012, 04:28 AM
1971superbee's Avatar
1971superbee
1971superbee is offline
Default Security system issues
I just went through this issue using hydrashcker's link below. I tried it a couple of times before including locking the hatch with the key. The system reset when I included that step.
Old 06-27-2012, 01:43 PM
tank99Dango's Avatar
tank99Dango
tank99Dango is offline
It just happened to me couple days ago. I unplugged the battery, waited 10 minutes or so, locked all the doors, connected battery, and unlocked the drivers door with the key...it beeped 3 times, and it started...
Old 12-03-2012, 07:11 PM
amberfrank's Avatar
amberfrank
amberfrank is offline
Had the same problem! just unlock the hatch the alarm turned ofc and it started right up!
Quick Reply: Vehicle Theft Security System won't turn off
