blower motor and power windows dead!
Old 01-03-2011, 09:26 PM
Buellstunter's Avatar
Buellstunter
Buellstunter is offline
Default blower motor and power windows dead!
On my 96 ram 1500 Both the power windows and the blower motor fuse block have no power to them. I assume they are somehow tied together Since I put 12v to the blower motor fuse and it worked fine along with the windows. Just cant figure out why they have no power to them. Anyone else have this issue?
Old 01-03-2011, 09:55 PM
There are also fuses under the hood, in the PDC. Big black box, right behind the battery. On the underside of the cover, it will tell you what is where. have a look.
Old 01-03-2011, 10:15 PM
Buellstunter
I did check the fuses under the hood as well. found nothing related to either the windows or the blower. Wasn't sure if anyone else has seen this or not. Was just going to give it switched 12v from the ignition switch, but would prefer to make it right.
Old 01-03-2011, 10:27 PM
Power windows have a circuit breaker in the fuse block in the truck. Power for that is fed from the ignition switch.
Blower motor has a relay in the PDC. Also, fuse 12 in the PDC. (according to the 01 wiring diagrams...... not sure just how accurate that is for a 96....)
Looks like power for the relay control is also drawn from the ignition switch..... wonder if your switch went bad?
Old 01-03-2011, 10:35 PM
Buellstunter
Ok, Ill check that out tomorrow. I read that one leg of the switch controls the heavy accesories, so it could be poss. that the switch is bad. Do you happen to know what wire on the steering columb coming from the switch i could test to see if it has juice? And Thank you for all your help.
Old 01-03-2011, 10:39 PM
According to the 01 diagram, its a 14 gauge, black wire with an orange trace.
Old 01-04-2011, 10:06 PM
Buellstunter
Sure Was the ignition switch. The pink wire with I believe black trace and the black W/orange trace were burned at the switch. and the switch was slightly melted so it isnt making contact. looks like new ignition switch is in order.
Old 01-04-2011, 10:16 PM
Awesome. Hope it solves the problem for you.
Old 01-04-2011, 10:25 PM
Buellstunter
Thanks again for the info.
Old 01-04-2011, 10:35 PM
Happy to be of assistance.
Quick Reply: blower motor and power windows dead!
