DODGE RAM 1500 2500 COOLING FANS engine radiator fan
Old 12-28-2010, 03:30 AM
Speedaholic's Avatar
Speedaholic
Speedaholic is offline
Default DODGE RAM 1500 2500 COOLING FANS engine radiator fan
I purchased these fans and I am wondering what would be the best way to install the fans..
I'm also wondering if I should use both bands..
I paid 56.11, is this a good deal for the fans?
If anybody can take pictures of your installed fan and post them up, that would be nice.
Link to the auctions.
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWNX%3AIT
Old 12-28-2010, 06:59 AM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
I hate to say it but the seller on ebay got you. There is not a DR that ever came with electric fans stock unless the newer 4th Gens come with them now. Thats why we buy OEM fans from other cars and retrofit them
A 10" fan rated at 1000 cfm isnt going to get it anyway but two might work if they are running at the same time. Plus you need a fan controller but thats easy.
Read this thread
https://dodgeforum.com/forum/3rd-gen...c-fan-diy.html
And buy this fan controller
BNIB - Hayden 3654 dual speed/fan controller
Old 12-28-2010, 07:03 AM
MikeHTally's Avatar
MikeHTally
MikeHTally is offline
Looks like they don't move enough air, either. You'll still need a controller, too.
Old 12-28-2010, 05:33 PM
Speedaholic
So, I got over on the fans.
I will take alook at the link..
Thanks again.
Old 12-28-2010, 05:46 PM
HammerZ71's Avatar
HammerZ71
HammerZ71 is offline
4th Gens are clutch fan too. Ain't no way they were made for a Ram.
You'll need 2400 cfm MINIMUM to keep the truck cool and I personally wouldn't feel comfortable with less than 2800 cfm. I paid a wee bit more than you at $260, but I can't complain, my Flex-A-Light came with everything needed, good instructions and moves 3300 cfm...
Old 12-28-2010, 06:55 PM
Speedaholic
Think, I can use it as a pusher by reversing blades?
Would that help?
Old 12-29-2010, 07:16 AM
MikeHTally's Avatar
MikeHTally
Well, you won't "reverse" the blades, you'll reverse the polarity on the motor. No, that won't help the sub-standard flow.
Old 12-29-2010, 08:10 AM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
Like i said, using both at the same time MIGHT work. But the bad thing is no one uses anything like that because no one wants to be the guinea pig. Thats why we all use something that has been tested and proven to work.
Old 12-29-2010, 01:34 PM
freestyledude's Avatar
freestyledude
freestyledude is offline
I've heard of people using a 'push pull' dual fan system where one is on the front and one on the back of the radiator. Might work well enough to make the fans usable?
Old 12-29-2010, 07:09 PM
MikeHTally's Avatar
MikeHTally
CFM is CFM. The two fans together apparently move about 2,000 CFM whether they're pushin' or pullin'. That's about 50% short.
Quick Reply: DODGE RAM 1500 2500 COOLING FANS engine radiator fan
