'03 4cyl 2.4L timing belt let go :( Question.
The timing belt let go on my kids 4cyl Caravan. Is this motor an "Interferance" type? IOW do the valves get crashed. Other damages?
Should a head rebuild run $2200-2500 or 1200-1600?
What does a whole motor rebuild run where you are? Installed?
Thanks for your combined Caravanic wisdom.
BobGlide
NM
BobGlide
NM
ok the 2.4 is freewheeling which means there is provisions for valve to piston clearance, However Valve to Valve interference can occur if cams are rotated independently. bad day for valves
no other damage internaly
were you booting it? just driving along? or did it break at idle?
myself id gamble and see if it warrants a teardown first
slap a new belt on it and see if theres cylinder pressure
im assuming you dont get dirty? or know someone who does?
at those prices I could get a whole motor&trans, and a new set of tires.
Heck you could probably buy a van with a good motor
not that the 2.4 isnt good just yours might not be
Ok, it's my son in-law, and he was driving like 30-40 and it just threw on the engine light and shut off like turning a key, (no bang or noise) he coasted to the side and towed it to the shop.
Later today I got word they planned to throw on a belt in the morning examine pulleys and try it out.
BobGlide
PS thanks for the excellent info guys.
BobGlide
Sorry to hijack thread , but just picked up a 1999 caravan with 2.5 has 185k on odo. What is the recommended replacement time on the timing belt?
on
