dash bezel removal ?
Old 12-18-2010, 02:23 PM
jerrylynnb's Avatar
jerrylynnb
jerrylynnb is offline
Default dash bezel removal ?
I need to remove the radio AND the dvd player (located underneath the radio). Is there a simple removal tooL? Or do you have to remove the bezel? Is there a procedure for removing the bezel? It is a 2007 grand caravan.
Old 12-18-2010, 05:04 PM
trophyslayer's Avatar
trophyslayer
trophyslayer is offline
for my 2006 there is a little plastic trim piece above the cup holders, the trim piece is about 1/2x5 it pulls right off, exposing 2 screws remove that, then rest of the surround pulls off (4 clips I believe, 2 on each side), it is held on by clips and takes a little preasure to pull loose, I did not use any tools when I did it
Quick Reply: dash bezel removal ?
