Blower motor not working
Old 12-13-2010, 06:10 PM
neil300zx's Avatar
neil300zx
neil300zx is offline
Default Blower motor not working
Hi
My Fan for my heating went kaput today when i switched it up from low speed to high speed any one know what fuse to check, if thats ok where do i go next
Cheers your speedy response will be appreciated as its bloody cold over here.
Neil
Old 12-13-2010, 07:51 PM
broncoremy's Avatar
broncoremy
broncoremy is offline
Can't speak for the '04 directly, but the '03 does not appear to have a fuse other than whatever fuse is on the ignition switch. The current that drives the fan motor will always be limited by the resistor block that determines fan speed, so Dodge must have taken that into account. Seems strange to me not to have it separately fused.
Very simple circuit. The connectors have come loose, a wire has come loose, the fan motor is burned or the resistor block is open. That is pretty much all there is.
Old 12-13-2010, 10:18 PM
That1guy's Avatar
That1guy
That1guy is offline
If you cant find a fuse or bad connection I would look into the key switch. Mine shorted out and gave my motor constant power and wouldn't shut with the key only the fan speed ****.
Old 12-13-2010, 10:58 PM
mike_r's Avatar
mike_r
mike_r is offline
I had the resistor go out in my 04. The only speed I had was high. Take the resistor out and measure it with a meter. It's located at the foot well of the passenger side, held in by 2 screws and has about 4 or 5 larger wires going to it.
Old 12-14-2010, 04:04 AM
neil300zx's Avatar
neil300zx
Cheers i will check out the said items
Old 12-14-2010, 01:04 PM
neil300zx's Avatar
neil300zx
Sorted, found the connecter at the rear of the switch not pushed in properly.
Cheers for the help
Old 12-14-2010, 01:37 PM
broncoremy's Avatar
broncoremy
A zero out-of-pocket cost fix. The best kind! That's great news.
Old 12-14-2010, 03:33 PM
neil300zx's Avatar
neil300zx
yes it is great news as the truck has cost me a few £ lately, new multi function switch, new rear light lens and bulb holder not to mention routine maintenance, tranny flush and new brake pads. still i love it
Old 12-14-2010, 04:37 PM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
Good news indeed when it is free and simple, especially this time of year.
Old 12-14-2010, 11:06 PM
That1guy's Avatar
That1guy
That1guy is offline
Cheers for the help
Which switch? The key or fan speed switch?
Quick Reply: Blower motor not working
