Dodge Durango 12v Power Outlets fuse.
Old 12-12-2010, 07:54 PM
kennybsdodge's Avatar
kennybsdodge
kennybsdodge is offline
Exclamation Dodge Durango 12v Power Outlets fuse.
In my 2000 Dodge Durango SLT 5.9L, my cigarette lighter plug works but my front dash 12v Power Outlet and the rear 12v Power Outlet towards the back gate are not working. I think I blew a fuse due to heavy usage with beacon lights for on the job safety. There is one 15amp fuse spot label for the cigarette lighter which is good, but where are the fuses for the 12v power outlets if there is any?
Thank you,
Kenny B.
Old 12-12-2010, 10:17 PM
hydrashocker's Avatar
hydrashocker
hydrashocker is offline
There is a hidden fuse panel behind the dash fuse panel. I think it has 4 fuses in it. Look VERY close.
sporta (09-07-2021)
Old 12-13-2010, 10:06 AM
Dans01Durango's Avatar
Dans01Durango
Dans01Durango is offline
IIRC, you have to move the seat all the way back and lower the backrest. Then you have to lie facing up from the doorway to get under the dash to get to the "secret" fuse panel.
Old 02-13-2015, 01:07 AM
Mortonight's Avatar
Mortonight
Mortonight is offline
Default backside of the fuse panel
its not easy to find, unless you know where to look. its literally the back side of the interior fuse panel. just above the E-brake under the dash. the 12v outlets run off the only 20 amp fuse which happens to be the only one you can't see. as you're laying uncomfortably under the dash with your head slightly smashed into the brake pedal you'll see a10 amp to the left and a 10 amp to the far right (fire wall side) left of that is a 5 amp.... and next to that is a 20 amp. you'll need either a fuse pulled tool (worthless) or a small pair of needle nose pliers to remove it. good luck! in other words its second from the left
Old 07-17-2017, 01:06 PM
Markell Walson's Avatar
Markell Walson
Markell Walson is offline
Default Hidden power outlet panel
On the back side of the fuse panel is a fuse panel. The twenty is the power outlet fuse.
The following 2 users liked this post by Markell Walson:
Donsheadache (11-06-2021), sporta (09-07-2021)
Old 09-29-2018, 09:47 PM
Melanie Alexander's Avatar
Melanie Alexander
Melanie Alexander is offline
Default Thank You
I found it and changed blown fuse. Thank you all.
Old 04-06-2019, 08:59 PM
Reese00's Avatar
Reese00
Reese00 is offline
Default Power outlet
Fuse is good in both spots normal box and hidden and still nothing any ideas
Old 09-06-2021, 11:01 AM
fkimdr's Avatar
fkimdr
fkimdr is offline
Default further question
the 20amp is power outlets anyone know what the other 3 fuses are??
Old 11-06-2021, 06:29 PM
Donsheadache's Avatar
Donsheadache
Donsheadache is offline
I have actually had to put one in. I guess I was missing mine. But now the outlet acts like it has a poor connection.
Quick Reply: Dodge Durango 12v Power Outlets fuse.
