Steering box leak?
Old 12-10-2010, 09:41 PM
smcandrew08's Avatar
smcandrew08
smcandrew08 is offline
Default Steering box leak?
So i have fluid leaking out of i think the steering box above the nut that attaches the pitman arm to it. Is there a seal or something in there that can go bad or is this a common problem? Not to sure about steering boxes.
Old 12-10-2010, 09:42 PM
HeyYou is online now
Yep, pitman shaft seal. It is even replaceable...... there was a DIY posted somewhere for it.... not really all that bad, and can even be done on the truck. Taking the fan, and shroud off would make it MUCH easier.
Old 12-10-2010, 09:55 PM
smcandrew08
dang i thought i have seen all the diys so far i guess i will have another look. Thanks.
Old 12-10-2010, 10:00 PM
Not sure if i found it on this site, or if it was linked from somewhere else......
Old 12-10-2010, 10:11 PM
smcandrew08
well either way its good to know i wasnt sure if it was going to be replaceable or not. So now that i know its back to work
Old 12-11-2010, 05:54 AM
zman17's Avatar
zman17
zman17 is offline
Retired Moderator - RIP
Quick Reply: Steering box leak?
