2000 Grand Caravan Speedometer Problem
Old 12-06-2010, 08:33 PM
bigengine's Avatar
bigengine
bigengine is offline
Default 2000 Grand Caravan Speedometer Problem
Hi Everyone,
New to this forum, and having trouble with my 2000 Grand Caravan instrument cluster.
The speedometer quit working, the shift selecter indicator and the odometer are both not working, and the door ajar light stays on. All this happened at one time.
Anyone had similar problems?
Thanks in advance for any help.
Old 12-06-2010, 09:05 PM
sapporo's Avatar
sapporo
sapporo is offline
I'd say it must be a common problem since this topic has shown up at least 20 times on this board in less than 1year. you can either replace the instrument cluster or have someone fix it.
Old 12-06-2010, 10:33 PM
master tech's Avatar
master tech
master tech is offline
Site Moderator & Tech
Welcome to DF
The most common problem is the printed curcuit board for the cluster. Has sapporo had said, you can have someone repair the old one or replace. I would do the replacement.
Quick Reply: 2000 Grand Caravan Speedometer Problem
