96 Stratus won't start, no spark, does get gas
Old 12-06-2010, 08:53 AM
Imre's Avatar
Imre
Imre is offline
Default 96 Stratus won't start, no spark, does get gas
Hi!
I'm here in Budapest, it's been unusually cold, well below freezing -- the first below freezing morning car was hard to start, simply cranked and nothing for a bit, then started to catch and came on.
Then I parked it for a couple of below freezing days and it just cranks -- gets fuel but no spark.
Fuses seem OK -- didn't pull them, just appear not blown.
96 Stratus 2.5 V6
Any ideas?
Thanks in advance for your help.
Best,
Imre
Old 12-06-2010, 11:35 PM
master tech's Avatar
master tech
master tech is offline
Site Moderator & Tech
Check the wires going to the crank sensor. And here is something i tried here,blow dryer on the PCM.
Old 12-07-2010, 06:21 AM
Imre's Avatar
Imre
Imre is offline
thanks Master Tech!
Will try, car is down the street, I live of a hill and... well, will let you know.
Imre
Old 12-07-2010, 06:25 AM
Imre's Avatar
Imre
Imre is offline
Basic question: what's the easiest way to see the crank sensor and where is the PCM?
Thanx,
Imre
Old 12-07-2010, 08:04 AM
Imre's Avatar
Imre
Imre is offline
Is the PCM under the hood, at the fuse box, next to it on the left side? Is there a simple test for it?
As for crank sensor, is it at the bellhousing? I didn't have a flashlight, pretty small and dark area, do I have to remove much to get to it? Is there an easy way to check it?
Another warmer day tomorrow forcasted, hopefully the snow will be melted and I'll remove them.
Thanks again,
Imre
Old 12-07-2010, 11:28 PM
master tech
The crank sensor is bolted to the transmission bellhousing, and the PCM would near the black box (PDC).
Old 12-08-2010, 05:08 AM
Imre's Avatar
Imre
Imre is offline
Thanks Master Tech!
Does the PCM have an aluninum casing?
Imre
PS: That's a mighty, and I mean mighty, fine V10 !!
Quick Reply: 96 Stratus won't start, no spark, does get gas
