Spark Plug, Distributor Cap, Rotor install update w/pictures
Old 12-04-2010, 04:59 PM
2000DakotaQuad's Avatar
2000DakotaQuad
2000DakotaQuad is offline
Exclamation Spark Plug, Distributor Cap, Rotor install update w/pictures
So I did the change on the distributor cap, rotor, spark plugs, and the wires. The first thing I noticed is the gap on the old plugs were way off. A 2000 Dakota 3.9L Magnum calls for a .40 gap. These were between .50 and .60. I replaced what looked to be the cheapest distributor cap known to man (aluminum terminals) with a Summit Racing brass terminal cap. The rotor I used was also a Summit Racing rotor. I used Summit Racing 8mm wires and NGK V Power copper plugs (gaped correctly I might add). Fired up the Dakota and all is good. Last thing now on my tune up list is the transmission filter and fluid.
Click on pictures for bigger view
File Type: jpg
Old 12-04-2010, 05:35 PM
Blaze10's Avatar
Blaze10
Blaze10 is offline
very nice
Old 12-04-2010, 05:36 PM
dodgeramguy85's Avatar
dodgeramguy85
dodgeramguy85 is offline
That looks good. When I did all mine it made my truck a lot better
Old 12-04-2010, 05:38 PM
Blaze10's Avatar
Blaze10
Blaze10 is offline
yeah myn was so bad it wasnt firing when i did myn lmao, had original plugs in it with 130 k on the tach
Old 12-04-2010, 08:55 PM
99-318's Avatar
99-318
99-318 is offline
Let me know on fuel mileage difference, I got the 5.2L I get about 400 kms to 70 dollars. wondering if I should do the same.. I need to do tie rod ends too.. dam,
Old 12-04-2010, 11:06 PM
dodgeramguy85
^^^ Im getting the same mileage as you I went from 8-9 to 11-12mpg when I did my plugs mine were bad!!
Quick Reply: Spark Plug, Distributor Cap, Rotor install update w/pictures
