Dash Gauges Not working No Bus Error
Old 12-02-2010, 11:27 AM
ep33510's Avatar
ep33510
ep33510 is offline
Default Dash Gauges Not working No Bus Error
I need some help Please. I have a 2000 Ram 1500 Club cab with 5.9L. The Dash gauges have stopped working, when you start the truck the gauges try to go through its clearing process but never make it. All the idiot lights are On and the Odometer ends up reading a No Bus message. I did the Odometer Chec and got the following codes 900,920,921,940,950,999. Any help would be appreciated, I did try reseating the main harness connector out on the fuse block in the engine bay. Is it normal for the hold down screw on the connector to never really tighten down? Mine will tighten to a point but as it gets to a point where it starts to feel snug it lossens up. If you back the screw up slightly it will feel tight but it doesn't feel right. Help!!!!!! Any input would be greatly appreciated.
Pat Collins
Old 12-02-2010, 11:47 AM
The codes are the cluster whining about not getting the data for the various instruments. Check the connector at the back of the cluster as well. Does the truck run/drive Ok?
The following 2 users liked this post by HeyYou:
franticvike (02-07-2023), Melissa Watt (04-25-2020)
Old 12-02-2010, 05:34 PM
zman17's Avatar
zman17
zman17 is offline
Retired Moderator - RIP
What is the "main harness connector out on the fuse block" you are talking about?
Old 12-02-2010, 06:28 PM
ep33510's Avatar
ep33510
ep33510 is offline
Yes it runs and drives fine, just fun flying blind with no idea about Fuel, Speed and Temps & Pressures.
ep33510
Old 12-02-2010, 06:33 PM
ep33510's Avatar
ep33510
ep33510 is offline
If you take off the large cover over by the battery, you will find the relays & fuses. If you look on the fuse block closest to the engine you will see a square 2 x 2 inch plastic connector with a bolt head right in the middle of it. If you back out that bolt you find it is a multi pin connector. It is that connector and its mounting bolt I have a concern about.
ep33510
Old 12-02-2010, 06:36 PM
ep33510's Avatar
ep33510
ep33510 is offline
Thanks for the info about the connector on the back of the cluster I will do that.
ep33510
Old 12-02-2010, 06:40 PM
Check fuse 14 in the fuse block in the side of the dash.
Old 12-08-2010, 06:31 PM
ep33510's Avatar
ep33510
ep33510 is offline
Default Dash Gauges Not working No Bus Error....... Update
Thanks for all the help, nothing I checked seem to fix the issue. For entertainment the gauges came to life yesterday morning when we hit 17 as a low. Loose pin somewhere?? LOL gotta lov it. I will have to see if it will stay alive once we start climbing above 30 again. Thanks again for all the input I was able to check things quickly and try to eliminate possible causes.
ep33510
Old 08-03-2019, 09:47 PM
Scott Russell's Avatar
Scott Russell
Scott Russell is offline
I know this thread is super old but I have a 2002 dodge durango with the same problem, did you figure out what the problem was? Thank you
Old 08-04-2019, 09:32 AM
He hasn't been here for nine years....... I suggest you start a thread in the Durango section.....
Quick Reply: Dash Gauges Not working No Bus Error
