Vent Selector is stuck????
Old 12-02-2010, 09:07 AM
HDRAMman's Avatar
HDRAMman
HDRAMman is offline
Default Vent Selector is stuck????
The vent selector on my truck is stuck on defrost. I flip the **** to the different settings and all the heat that comes out is only from the defrost vents.
How do I fix? My feet are freezing and my face is on fire.
Old 12-02-2010, 10:39 AM
Silver_Dodge's Avatar
Silver_Dodge
Silver_Dodge is offline
If it is not a problem with the vent blend mechanism itself, then it is probably a vacuum leak you need to find.
Old 12-02-2010, 10:40 AM
dodge dude94's Avatar
dodge dude94
dodge dude94 is offline
Banned Goober Smoocher
Couldn't it also be a sign of the wildvents?
Old 12-02-2010, 11:25 AM
Silver_Dodge
The what in the what now?
Old 12-02-2010, 11:49 AM
HeyYou is online now
Wild vents is vents switching back to defrost on acceleration. (or, climbing a hill, or any other high engine load event.)
Look under the hood, passenger side, back by the firewall. Vents are controlled with vacuum, and it appears you don't have any. I would be a broken line somewhere between the manifold, and the firewall.
Old 12-02-2010, 02:35 PM
Silver_Dodge
Actually, the leak could be in just about any part of the vacuum system. When mine had the "wild vents", it was a leak in the vac line by the CAD on the front axle.
Old 12-02-2010, 02:40 PM
I think he has more than just a 'leak' though. I think something is either broken off, or disconnected. Start at the 'easy' part, and see what comes up.
Old 12-02-2010, 04:04 PM
Silver_Dodge
True.
Old 12-02-2010, 06:35 PM
EHS22's Avatar
EHS22
EHS22 is offline
whenever i have the AC on in my 1997 1500 and i give it more a little throttle or im going up a hill the AC will stop blowing out the vents. is this the "wild vents" y'all are talking about? so its caused by a vaccum leak?
Old 12-02-2010, 06:48 PM
That is indeed wild vents, and is usually caused by a failed check valve up by the intake manifold. I think there is a DIY fix thread in the FAQ section for it.
Quick Reply: Vent Selector is stuck????
