Old 08-05-2015, 12:28 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: 4WD
Print Wikipost
Engaging 4 wheel drive?
Old 11-26-2010, 06:37 PM
oxygen454's Avatar
oxygen454
oxygen454 is offline
Question Engaging 4 wheel drive?
When I bought the truck about a year or so ago, I noticed that the instructions to engage 4 wheel are partially rubbed out.
From what I gather it says...
To engage HI, shift while driving
To engage Lo, Stop, put truck in neutral, shift to 4 low fast and hard. Then put truck to drive.
Does this sound right? I find sometimes it makes a grinding noise. From what i have heard, that is normal. Also seems to pop out of 4wheel with a bang.
(also says do not drive on hard surfaces, its hard on it... must drive on dirt, snow etc.
Whats going on here? And does anyone have a good picture of there instructions on there visor?
Old 11-26-2010, 06:52 PM
tmacdakota's Avatar
tmacdakota
tmacdakota is offline
That's about it for the instructions. Mine does the same, jumps out of 4L but without a bang, but 4H works great...shifts right in a idling speed. My mech told me to shut it off and put it into low, then go, but haven't tried that yet.
Old 11-26-2010, 07:02 PM
93formula's Avatar
93formula
93formula is offline
i thought 4lo needed to go in while truck is slightly in motion? mine pops in/out too, i hardly use it, also check the linkage (i have yet to adjust mine), but this recent snow dump all ive been using is 4hi.....with the 24's LOL
Old 11-26-2010, 09:25 PM
tmacdakota's Avatar
tmacdakota
Maybe on 95 and later Daks, but up through 93 you have to be stopped and in N to get into 4L...no wueno otherwise...but you can just run at idle speed and slip it into 4H.
Old 11-26-2010, 09:44 PM
will4557's Avatar
will4557
will4557 is offline
I dont think you are supposed to shift it fast and hard into 4lo. I always pull with a constant pressure and if it wont go in let the truck roll a little or move it a little then try again! Maybe thats just the way I do it, but who knows. lol. It will tell you in the owners manual of the truck if you still have that!
Old 11-27-2010, 02:11 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Crazy4x4RT is offline
Here is a copy and paste from the Owners Manual.
NV-231 Transfer Case
The NV-231 transfer case offers 4 mode positions. Use the appropriate mode for the conditions described below:
2H
Rear wheel drive high range - Normal street and highway driving.
4H
Four-wheel drive high range - When driving conditions require more traction than two-wheel drive provides.
N
Neutral - Disengages both driving axles. To be used for towing only. See towing instructions for more information.
4L
Four-wheel drive low range - When maximum pulling power is require. Do not exceed 25mph (40kph).
Shifting Procedure
2H to 4H or 4H to 2H
Shifts between 2H and 4H can be done with the vehicle stopped or in motion. With vehicle in motion, the transfer case will engage/disengage faster if you momentarily release the accelerator pedal after making the shift.
4H to 4L or 4L to 4H
Shifting can be performed with the vehicle rolling 2-3 mph (3-5 km/h) or completely stopped. Slow the vehicle to under 3mph, shift automatic transmission to NEUTRAL (N) or depress clutch on manual transmission. Shift transfer case lever without hesitation to the desired mode. Pausing in transfer case NEUTRAL (N) may require shutting the engine off to avoid gear clash while completing the shift. Do not attempt to shift to or from 4L with the transmission in gear.
Old 11-27-2010, 02:27 PM
melodytoinvent's Avatar
melodytoinvent
melodytoinvent is offline
I'd personally never engage it while moving even though my manual says I can. Just doesnt sit right with me and seems hard on the truck and why not stop since you gotta slow to around 2 mph anyway. I always stop, put the truck in nuetral, and pull the shifter to whatever I'm putting it into, put the truck in reverse and let it roll a lil, then back to drive and go. Thats just how I was taught and I always have better results like that. No grinding, popping out, or gear clash.
Old 11-27-2010, 05:50 PM
tmacdakota's Avatar
tmacdakota
I checked my TC fluid today and did the linkage adjustment in the service manual...now it stays in 4L instead of wanting to pop out. I stop dead, put it in N and ease it firmly into 4L then go.
Quick Reply: Engaging 4 wheel drive?
