Dodge Neon 1996, heater is on but no heat
Old 11-22-2010, 03:18 AM
bornok's Avatar
bornok
bornok is offline
Default Dodge Neon 1996, heater is on but no heat
Kindly advice what to do with the 1996 model dodge neon, when i open my heater and the temperature is already high, the heater is not enough heat distribution. Its already winter here in canada and need so much the heater. what could be the possible cause and what to fix?
Old 11-22-2010, 04:43 PM
bg1995redneon's Avatar
bg1995redneon
bg1995redneon is offline
Either it is a plugged heater core and you can try to backflush it by disconnecting both hoses at the firewall and use a hose to inject water into both the left and right to unblock it (may work if the blockage is not too bad, otherwise you will have to replace it), OR, your temp selector switch to open the valve allowing the hot water to circulate through the core is busted and not allowing the hot water to flow through the core (or partially opening allowing only a little bit to flow).
Old 12-01-2010, 05:59 PM
ALLDATAdiyINFO's Avatar
ALLDATAdiyINFO
ALLDATAdiyINFO is offline
Former Vendor
Is air blowing from the vents?
Old 12-02-2010, 11:15 AM
hemi4spd's Avatar
hemi4spd
hemi4spd is offline
are the heater hoses from engine to firewall hot to touch?
Old 12-02-2010, 05:29 PM
bornok's Avatar
bornok
bornok is offline
Yes the hoses are hot
Old 12-02-2010, 05:30 PM
bornok's Avatar
bornok
bornok is offline
Yes, the air is blowing but its cold.
Old 12-02-2010, 05:32 PM
bornok's Avatar
bornok
bornok is offline
Is there any idea how much is he labor for replacement of heater core?
Old 12-03-2010, 10:28 AM
bg1995redneon
I do not have a Dodge Service Labor chart to go by, and some mechanics charge by the job, not per hour.
I would estimate that it will cost you about 3 hours of labor at a shop (at whatever rate per hour they charge) + parts (core is $72 at advanceauto.com).
As I said originally, you may have a case where your heat selector switch is malfunctioning. If it is not fully opening the valve holding back the hot water from even getting into the core, then that is your problem.
Have you tried my suggestion of back flushing the core? Disconnect the heater hoses at the firewall and alternate back and forth between the two ports in forcing water thru the core - use a hose with as much pressure as it will put out. DO NOT hook up a high pressure sprayer unless you want to risk rupturing it! if it is not too badly plugged, you will see glop and/or goo come out in fits and bits and pieces. If you cannot get water to force its way through, then you can replace it. If water starts flowing freely from one port , switch to that port and see if it comes out freely from the other way. If it does, your core is clear. All of this costs you nothing but some time and may save you some serious cha-ching.....
Old 12-07-2010, 10:32 PM
hemi4spd's Avatar
hemi4spd
hemi4spd is offline
Im doing a heater core in a sunfire tomorrow The book says 5 hours.
I'm sure the neons labour is similar.
Damn GM junk I should be charging more
Quick Reply: Dodge Neon 1996, heater is on but no heat
