power locks going crazy
Old 11-17-2010, 11:09 PM
allen3944's Avatar
allen3944
allen3944 is offline
Default power locks going crazy
i have a 97 caravan and when driving,the door locks will click as if they are locking on their own.the wife said it happened about a dozen times this morning on a 4 mile trip to and from school.sometimes they will lock by themselves with van switched off in the driveway.also door ajar light came on and all doors were shut.could these be related?anybody have any clues as where to start checking? thanks in advance,allen
Old 11-18-2010, 12:21 AM
master tech's Avatar
master tech
master tech is offline
Site Moderator & Tech
Replace both sliding door ajar switches.
Old 11-18-2010, 11:45 PM
allen3944's Avatar
allen3944
what are the door ajar switches?the two together or the single switch?with all doors shut and no keys in i can lock the doors and sometimes they will unlock right back.
Old 11-19-2010, 08:12 AM
jumpdrive2's Avatar
jumpdrive2
jumpdrive2 is offline
Default door ajar switch/door jamb switch
About $11.00 apiece
Old 11-19-2010, 05:50 PM
allen3944's Avatar
allen3944
thanks guys this clears up alot.
Old 11-20-2010, 12:55 PM
allen3944's Avatar
allen3944
where in the world do you get these for $11.00 apiece?i checked advance auto and they said factory direct for $49.00 each.
Old 11-20-2010, 04:36 PM
jumpdrive2's Avatar
jumpdrive2
Default door jam switch for sliding doors
Autozone $10.99
Code:
http://www.autozone.com/autozone/parts/Duralast-Door-Jamb-Switch/1997-Dodge-Caravan-2WD/_/N-j938hZ8iihf?counter=1&filterByKeyWord=door+switch&fromString=search&itemIdentifier=229370_0_2486_
Old 11-20-2010, 05:43 PM
A14Austin's Avatar
A14Austin
A14Austin is offline
I had the same problem. If you want to try buy sone Electical contact spray (sold at local parts store) and spray all the terminals under the door panel. This worked for my old truck. It happeneds if moisture builds up over time, or if youve ever got the inside wet if it rained ect.
Quick Reply: power locks going crazy
