2003 Neon SXT - Check engine light issues
Old 11-09-2010, 09:57 PM
knighk18's Avatar
knighk18
knighk18 is offline
Default 2003 Neon SXT - Check engine light issues
The car is a 2003 Dodge Neon, my best friend's car. The check engine light has been on (like 90% of the time) for almost 2 years, and apparently her cruise control has been broken as long (although I just found that part out tonight). She's taken it in 3 times and told it was the camshaft sensor causing the check engine light to stay on...and each time they replaced it, it came back on within weeks.
She ended up having the transmission replaced about 3 months ago, and they also told her the check engine light was due to the camshaft sensor, so they replaced it. She drove out of the parking lot, it came back on, so she took it back, and they told her the sensor was brand new and that's the only thing it could be. They then tried to reset the check engine light and that didn't work either. So she gave up.
But now, she's got to renew her tags, and her car won't pass emissions with the check engine light on. Last week, the car starts backfiring and making a knocking noise. Her cruise control does not work, either. So she takes it to a different place, and they fix those issues, tell her the camshaft sensor is causing the check engine light to come on, she explains that it's already been replaced 5 times, but they do it again anyway. She leaves, it's off, takes it to the emissions place and fails, but they tell her she has to drive for a certain number of miles after sensors are reset before it'll pass emissions. So we drive around for about 25 miles, and the light's back on. Any idea what it could be BESIDES a camshaft sensor? Neither of us knows anything about cars, but since that stupid sensor has been replaced 5 times and the light is always on, it seems logical that just maybe something else could be solving the problem. And how do you get a mechanic to trust something besides the diagnostic tool which is telling him something is broken that doesn't actually seem broken? This is now 4 separate mechanics telling her the same thing - the camshaft sensor is causing the check engine light to come on. So either something is causing the camshaft sensor to cause the light to come on, or that's not the problem. Any ideas? She's taking it back to this mechanic tomorrow, and it would be great to have an idea to walk in with, since no one seems to know anything other than camshaft sensor
Old 06-11-2013, 10:34 AM
afidler62's Avatar
afidler62
afidler62 is offline
Smile 2003 Dodge Neon
For 2 years I put up with the check engine light on and a cruise control that only worked part time. Just to let you know there is no corrolation between the check engine light and the cruise control. The light was on because the new crank/cam shaft sensor I had put on was defective. The cruise didn't work because the brake switch failed. Changed that and now the cruise works. Once again I love my neon.
Old 09-24-2014, 05:45 PM
eeesfolks's Avatar
eeesfolks
eeesfolks is offline
Default Check Engine light always comes on
Bought a used 2003 Dodge Neon with 125,000 miles - Check engine light came on for Cam Sensor (car was running fine). Replaced Cam Sensor and Crank Sensor. Had to have the computer reprogrammed. Made it worse - replaced timing belt. Still worse - barely ran. Replaced entire computer. Within 1 week - Check engine light is on. This time it is the gas cap. Replaced with new gas cap. Have driven the car two weeks and guess what....the check engine light is on again. Will be taking it to auto zone to see what the problem is now. Have had the car two months and the check engine light has been off a total of about two weeks.
Quick Reply: 2003 Neon SXT - Check engine light issues
