Instrument panel light bulbs?
Old 10-31-2010, 09:38 AM
z34rick's Avatar
z34rick
z34rick is offline
Default Instrument panel light bulbs?
How do you replace ligh bulbs in the instrument panel on a 2006 Grand Caravan?
Thanks.
Old 10-31-2010, 11:48 AM
hemi4spd's Avatar
hemi4spd
hemi4spd is offline
the cluster needs to be removed then a simple quarter turn of the bulb base and out they come, now finding the right bulb may be the hardest part, the little itsy bitsy bulbs arent sold in the auto stores, usually a trip to the dealer or junkyard is required.
if you need instructions on how to pull apart the dash and luster I can provide u with them
Old 10-31-2010, 10:12 PM
z34rick's Avatar
z34rick
z34rick is offline
Default Instrument cluster ligh bulb replacement?
Yes. I need to know how to remove the instrument cluster, so I can replace the bulbs.
Thanks.
Old 10-31-2010, 11:47 PM
master tech's Avatar
master tech
master tech is offline
Site Moderator & Tech
REMOVAL
1. Disconnect and isolate the battery negative cable.
2. Remove Over Steering Column Bezel by lifting it straight up with a firm pull.
3. Remove the four cluster bezel attaching screws.
4. Tilt the steering column in the full down position.
5. Pull rearward on the cluster bezel and remove.
6. Remove the four screws holding instrument cluster to instrument panel.
7. Rotate top of cluster outward.
8. Disconnect the cluster harness connector.
9. Remove instrument cluster from instrument panel.
Old 11-03-2010, 07:00 AM
z34rick's Avatar
z34rick
z34rick is offline
Thanks. Exactly what I needed.
Old 11-13-2010, 06:02 AM
papaduck's Avatar
papaduck
papaduck is offline
Originally Posted by master tech
REMOVAL
I have had to replace a bulb on my '04 and I could not complete step 8. I did not want to do any damage to the cluster so gave up and found a way to replace the bad bulb. I now have another bad bulb and want to replace all the bulbs. It would be much easier if I could get the cluster harness connector loose.
What step(s) are needed to get it loose?
Old 11-13-2010, 07:45 AM
z34rick's Avatar
z34rick
z34rick is offline
Default I had the same issue.
I replaced the bad bulbs without disconnecting the harness. I didn't want to take a chance on damaging it and there was enough room to easily replace the bulbs.
Rick
Old 01-12-2013, 04:58 PM
punt1959's Avatar
punt1959
punt1959 is offline
Default Replacing dash light bulbs on caravan
This is what I did on my van. You can do this if you have a hard time finding the PC74 bulb (Bulb and base together) or if you want to replace original bulb with an LED type light.
This is an easy way to save the base off the old bulbs.
Old 10-09-2013, 12:40 PM
raywascher's Avatar
raywascher
raywascher is offline
Default Bulb replacement for a 2007 Town&Country
REMOVAL
Is the procedure the same for a 2007 Town and Country also?
Old 11-03-2016, 08:42 AM
Paul Gabriel's Avatar
Paul Gabriel
Paul Gabriel is offline
Default Bulb went out on my temp gauge on my 2010 Dodge Caravan
Bulb went out on my temp gauge on my 2010 Dodge Caravan, Can bulb be replaced or do I need a whole new Instrument Cluster. What is the average cost of fixing this problem? Any help would be apreciated
Quick Reply: Instrument panel light bulbs?
