Weired oil light flashing and beeping problems
Old 10-27-2010, 08:06 AM
mppittman's Avatar
mppittman
mppittman is offline
Default Weired oil light flashing and beeping problems
OK i have a 04 neon se and every once in a while the oil light comes on and wont stop beeping and flashing when i come to a stop and once i get moving it shuts off. And yes it has the right amount of oil in it. Sounds like a oil preassure sending unit to me. If anybody could confirm or verify that for me and tell me where it is located and how difficult it will be to change that would be great. Thanks
Old 10-27-2010, 10:31 AM
showsxt's Avatar
showsxt
showsxt is offline
I had the same problem its the oil pressure sensor you can get it at autozone for 10.99 and its called a oil pressure switch there it will solve your problem.
Old 10-27-2010, 03:02 PM
darthroush's Avatar
darthroush
darthroush is offline
Section Moderator
Get the sensor, a 1 1/16" deep socket and some thread sealant and have fun reaching it! The deep socket does make the job quite a bit easier though.
Quick Reply: Weired oil light flashing and beeping problems
