Diesel General Discussion This section is for general discussions about your Deisel RAM. Non tech related RAM threads belong here.
47RE Transmission Oil & Filter Change Capacity?
Old 10-24-2010, 08:41 PM
Two Man Crew, Inc.'s Avatar
Two Man Crew, Inc.
Two Man Crew, Inc. is offline
Default 47RE Transmission Oil & Filter Change Capacity?
98 Cummins 24 valve, 190K.
Just changed oil and filter in transmission. Filled with 3-1/2 qts Valvoline ATF 4 synthetic. Engine mildly warm. Run thru gears. No oil on dip stick. Added 1/2 qt, still no oil on dip stick. Manual says 4 quarts is supposed to be all that is needed.
I am second owner. Could original owner have put bigger pan on? Is there any other reason for it to need more oil?
Old 10-25-2010, 03:39 PM
Two Man Crew, Inc.
Default Stock pan is 4-1/2 qrts more than Haynes manual says.
Just kept on adding ATF until hit marks. Stock pan on cummins must be deeper than V8 & V10.
Old 01-12-2011, 08:36 PM
Tazman40's Avatar
Tazman40
Tazman40 is offline
ya i just did mine too and the manual said 4 qts but i think all said and done i put in almost 7
Quick Reply: 47RE Transmission Oil & Filter Change Capacity?
