Need a 1999 Transmission Oil Pan
Old 10-24-2010, 08:00 AM
Durangible's Avatar
Durangible
Durangible is offline
Red face Need a 1999 Transmission Oil Pan
Hello all,
Does anyone know where online or otherwise to buy a transmission oil pan for a Durango?
Or does anyone have one, in at least good condition, they are willing to sell?
I went to change the filter and the oil pan is rotted out!
Thanks.
Old 10-24-2010, 09:41 AM
shrpshtr325's Avatar
shrpshtr325
shrpshtr325 is offline
THE ULTI-MOD
you could check the junkyard, or the dealer (might be the only option for a factory sized pan) i think jegs or summit might have a slightly larger pan which would fit and just require more trans fluid in order to fill
Old 10-24-2010, 08:27 PM
hydrashocker's Avatar
hydrashocker
hydrashocker is offline
+ 1 sharps
Junk yard or aftermarket for about $200 or so for a deep pan.
Old 10-24-2010, 08:59 PM
IndyDurango's Avatar
IndyDurango
IndyDurango is offline
Old 10-26-2010, 09:00 AM
Durangible's Avatar
Durangible
Thanks for everyone's replies!
I found some models on Summit Racing.
My question now is to which type of transmission the '99 actually has.. One trans oil pan says it is for these trans types:
Transmission Type: Torqueflite A-904 and/or Torqueflite A-999
Link: http://www.summitracing.com/parts/DC...ery=Make|DODGE
and the other is for
Transmission Type: Torqueflite 727, with application notes: 1966 and later.
I also found this one: http://www.xtremediesel.com/bd-power...7transpan.aspx
but with a price tag of nearly $240, that is a bit out of my range at the moment.
So does anyone know which transmission type comes stock on the '99??
Thanks!
Old 10-26-2010, 09:26 AM
shrpshtr325
THE ULTI-MOD
if you have the 5.9l it should be a 46re, and the 5.2 comes with a 44 iirc
Old 10-26-2010, 03:29 PM
hydrashocker
5.9L comes with a 46RE
5.2L comes with a 42RE or 44RE
4.7L comes with a 45RFE, however you do not have this because yours is a 1999.
Old 10-27-2010, 10:09 AM
Durangible's Avatar
Durangible
Ok, thanks.
I have the 5.9L, so that is the 46RE transmission. So which trans oil pan do you think is compatible with it?
or
Torqueflite 727 (1966 and later)
Old 10-27-2010, 09:14 PM
hydrashocker
It's an A-518 transmission.
Check into this thread: https://dodgeforum.com/forum/2nd-gen...re-tranny.html This thread is in the 2nd generation Ram area but it is full of good information. Also you can talk to master tech about part numbers for OEM pans or such depending on how much you wanna spend.
Old 10-28-2010, 12:59 AM
master tech's Avatar
master tech
master tech is offline
Site Moderator & Tech
Hughes Performance HP1580 - Hughes Performance Deep Aluminum Transmission Pans
View Image and Compare
Compare Transmission Pan, Deep, Aluminum, Natural, Finned, Chrysler, Torqueflite 727, A-518, Each
Part Number: HUP-HP1580 More Detail …
Quick Reply: Need a 1999 Transmission Oil Pan
