2000 Neon with broken timing belt
Old 10-04-2010, 12:15 PM
Keniki's Avatar
Keniki
Keniki is offline
Default 2000 Neon with broken timing belt
I am trying to replace the Timing Belt on my Neon and am having trouble with the right engine mount. Do I unbolt it from the frame (four 8mm bolts) or does it come apart with the large Torx screw in the center.
Old 10-04-2010, 04:16 PM
darthroush's Avatar
darthroush
darthroush is offline
Section Moderator
You unbolt it from the frame, but you need to outline it with a marker or something as it needs to be bolted into the same exact position it came off. That position has to do with correct engine/transmission alignment.
Old 10-05-2010, 10:54 AM
Keniki's Avatar
Keniki
Keniki is offline
OK, I have it marked and unbolted, but there is a boss about 4 inches in diameter on the mount that goes into a hole in the frame that will not let me remove the mount. I have the engine jacked over about a half inch but the boss is still into the large hole. DoI need to move the engine over farther to the left?
Old 10-05-2010, 07:01 PM
darthroush's Avatar
darthroush
Section Moderator
I don't have the shop manual ATM, but I believe the engine brace needs to come out? Maybe someone else in the mean time knows...
Old 10-05-2010, 09:38 PM
leadspud's Avatar
leadspud
leadspud is offline
Remove the torx bolt and the mount will come right out
Old 10-12-2010, 10:17 PM
martiniac's Avatar
martiniac
martiniac is offline
I just did this with my 2000. I jacked the engine up very high and had to use ratchet straps to get the engine in the correct position. Now working on crank seal, water pump, tensioner, etc. while the head is at the machine shop being reworked.
Car should look/drive pretty good when I'm done. Pics to come!
Old 10-13-2010, 08:59 AM
Keniki's Avatar
Keniki
Keniki is offline
I was able to get to the problem by jacking the engine after I took apart EVERYTHING on the right side of the car. I hope I can remember how to put it all together again. The problem was the water pump locked up tight. No leakage but also no rotation and thus the timing belt failed. Car was at a stop when this happened so I am hoping for a good compression check when I get the belt on.
Old 11-14-2010, 09:07 AM
Keniki's Avatar
Keniki
Keniki is offline
Default 200 Neon with broken timng belt
I got it all back together and no left over parts. started right up. The water pump had frozen solid causing the belt to fail. Thanks to all who had input into fixing this problem
Quick Reply: 2000 Neon with broken timing belt
