Dodge Dakota The tough, mid size pickup, the Dodge Dakota. The Dodge Dakota has everything the big boys do with a mid size truck price.
3.9L to 5.9L engine swap
Old 10-01-2010, 12:07 AM
Danthedakotaman's Avatar
Danthedakotaman
Danthedakotaman is offline
Exclamation 3.9L to 5.9L engine swap
Hey guys, I currently got the 3.9L V6 with zero ***** and wanna throw in a 5.9L, would it fit and can the tranny take the extra strain?
Old 10-01-2010, 12:11 AM
Danthedakotaman
or is the 5.2L in general a better engine?
Old 10-01-2010, 12:50 AM
dbilik's Avatar
dbilik
dbilik is offline
I personally like the 5.2 because of the slightly better MPG, and more metal in the block, but then again I am not going for power.
No, your trans won't take the 5.9. It will fit though.
Old 10-01-2010, 12:58 AM
Danthedakotaman
yea i read that the 5.2 is not bad at all, it would fit without any major changes?
Old 10-01-2010, 10:37 AM
dbilik's Avatar
dbilik
dbilik is offline
Well that depends on what you consider major changes. You are changing out your drivetrain so.... neither the 5.9 or 5.2 are bad engines. I just like the 5.2 for my purposes more. Read the faq for info on the swap.
Old 10-04-2010, 02:05 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Crazy4x4RT is offline
Danthedakotaman what year is your truck? I can move it into the proper section.
Old 10-04-2010, 08:29 PM
dbarnes's Avatar
dbarnes
dbarnes is offline
what year truck do you have and what year 5.9 are you planning on using
Old 11-11-2010, 09:38 PM
BrandNew's Avatar
BrandNew
BrandNew is offline
just so you know what ever motor you do end up doing it has to be the same year as your truck or newer to pass inspection.
Old 11-13-2010, 11:39 AM
dbilik's Avatar
dbilik
dbilik is offline
Actually that's not entirely true, to pass emissions it varies from state to state. In my area, I was told I need to maintain all of the same emissions controls which are listed for my vehicle and pass emissions. Also, if you are OBDI, they don't even test those vehicles in the Chicago area anymore. My brother out in Vegas does have to still pass emissions with his 1993 Dakota, so it all just depends.
Old 04-08-2011, 03:17 PM
dakota_drop_tops's Avatar
dakota_drop_tops
dakota_drop_tops is offline
A swap from a 3.9 to a 5.2 is easy as far as the hardware goes if it is a LA to Magnum swap. Same motor mounts, flex plate and torque converter. Now if you go to a 5.9 it is a different ballgame.What I did was replace the entire drive train from a donor wreck. The output of the trans is the same for all Automatics. If you are going to put theV8 into a 1st gen Dakota then you will have to remove the fan and put electric fans in front of the radiator as the v8 is 4.4" longer than the V6. Not hard but be aware.
Quick Reply: 3.9L to 5.9L engine swap
