Whats the biggest tires i can fit on a stock ram 1500 4x4
Old 09-30-2010, 06:05 PM
atowngolfer's Avatar
atowngolfer
atowngolfer is offline
Default Whats the biggest tires i can fit on a stock ram 1500 4x4
Whats the biggest tires i can fit on a stock ram 1500 4x4? I need new tires and want to get bigger tires than the 31s on it now
Old 09-30-2010, 07:22 PM
07silverbullit's Avatar
07silverbullit
07silverbullit is offline
Could be wrong, I think leveled you can fit 33's????
Old 09-30-2010, 07:28 PM
glass3222's Avatar
glass3222
glass3222 is offline
The stock tires that come on 20s are 33". You can go a little wider than stock, but not much. Leveled you can go to a 35, width being limited again.
Old 09-30-2010, 11:48 PM
Marx's Avatar
Marx
Marx is offline
33.4x11
Old 10-01-2010, 12:27 AM
Bonzen's Avatar
Bonzen
Bonzen is offline
I have the 2" Bilstein leveling shocks, and it clears a 285/70/17 easy (33"x11.5") on my stock wheels. I am pretty sure you can clear a 35 if you run aftermarket wheels that kick the tire out a bit from the frame and upper control arm. If you run a 35 on the stock wheels it will rub on the upper arms for sure, and most likely on the frame/fenderwells when you turn.
Old 10-01-2010, 12:38 AM
07silverbullit
Do you need spacers for the a level with 35's. Or will they only rub at full lock?
Old 10-03-2010, 07:23 AM
Mopartoya's Avatar
Mopartoya
Mopartoya is offline
Mine is a 2006 1500 4x4. I'm running 33x13.50x20 Mickey Thompson ATZ's on 20x10 rims... no lift, no rubbing.
Quick Reply: Whats the biggest tires i can fit on a stock ram 1500 4x4
