Will these tires fit?
Old 09-27-2010, 04:33 PM
matt0852's Avatar
matt0852
matt0852 is offline
Default Will these tires fit?
Hey guys, ran into a bit of tire trouble and ended up with a slash in my sidewall. Seeing as my tires were just about to be changed anyway I figured I'd just go ahead and buy all four. Now here's the question, I have 215/75/15 Firestone passenger tires on there right now. I want to go bigger and I found Goodyear Tracker 2 at Walmart 235/75/15 and was wondering how clearance would be. Int he FAQ2 I know it says they'll fit but my truck does sit lower in the front. what I call squatting haha. Anyone have these? It's stock height by the way and 2x4. Another concern is Walmart. Are they guinna give me a hard time since they're not stock size? I remember my dad got tires there once and they wouldn't put them on because they were bigger than the stock size. Thanks for any input.
Old 09-27-2010, 04:56 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Crazy4x4RT is offline
Using a tire calculator like this one. http://www.4lo.com/calc/gearmetric.htm
Says your stock tire is 27.7 x 8.5in.
And the 235 is 28.9 x 9.3.
So that is 1.2in x .8
Get a tape measure and add .6in above the tire and see if you got the space. And see if you got .4in on the inside of the tire.
My guess you could easily fit even larger tires.
As far as Walmart not letting you get larger tire, I'm not sure. It does sound like something they might say, due to them not wanting to be liable for going beyond stock requirements.
There are tons of tire shops you can go to that WIll get what you want.
Old 09-27-2010, 05:15 PM
festerw's Avatar
festerw
festerw is offline
You should be alright getting them mounted there as it was a stock size on the 4x4's and they just seem to look at overall model lines.
Old 09-27-2010, 10:44 PM
fox's Avatar
fox
fox is offline
What a stupid policy from wal-fart. If you have too just buy the tires from them and have them mounted at a different tire shop.
Old 09-28-2010, 07:02 AM
matt0852's Avatar
matt0852
matt0852 is offline
Thanks for the help guys, much appreciated! I was thinking that as well fox! and Crazy 4x4 thanks for that calculator. I'll try it once I get home today. I hope you're right festerw. It would make it more convenient for me.
Old 09-28-2010, 04:52 PM
luthoro's Avatar
luthoro
luthoro is offline
Yeah, they will fit fine on a 2wd. I have 235-75-15 Trail Guide A/P tires on mine.
Old 09-29-2010, 04:37 PM
Deerkiller9991's Avatar
Deerkiller9991
Deerkiller9991 is offline
Do you have the stock 15x6 rims? I do and I want to go buy bigger tires that what I have on the back but with the 6" rim, whats the biggest I should go? I already have some 30x9.5x15's on their but the tires I want are only 31x10.50x15's
any tips/ideas?
Old 09-30-2010, 04:30 PM
luthoro's Avatar
luthoro
luthoro is offline
Yeah, they are on the stock 15x6 alloys.
Old 09-30-2010, 08:05 PM
melodytoinvent's Avatar
melodytoinvent
melodytoinvent is offline
Wal-Mart is dumb like that for liability reasons like Crazy said, but they put my 31s on with no problem. They just had to check if they'd rub first. They do lol but they didnt put em on and drive it so yeah.
Quick Reply: Will these tires fit?
