Neon SRT-4 Dodge Neon SRT-4 is the pocket rocket that took the import scene and turned it upside down.
Does Mopar/Catback Exhaust Increase HP?
Old 05-31-2005, 04:02 PM
SRT4STYLIN's Avatar
SRT4STYLIN
SRT4STYLIN is offline
Default Does Mopar/Catback Exhaust Increase HP?
I am looking at getting the Mopar exhaust for my SRT4, and am wondering if that will increase my horsepower or torque at all since I am running stock... Well I have a CAI and OCC...
Is the exhaust something that only helps once you mod your car with stage 1,2, or 3 or other turbo mods and such???
Thanks
Andrew
Old 05-31-2005, 04:40 PM
SRT_YA's Avatar
SRT_YA
SRT_YA is offline
Default RE: Does Mopar/Catback Exhaust Increase HP?
5 HP maybe?? even with Stages it's not leaps and bounds... and you won't feel 5HP... just a guess.... the Mopar exhaust is rumored to only be good up to 300(?) HP...
Old 05-31-2005, 04:53 PM
roachnigga's Avatar
roachnigga
roachnigga is offline
i heard the same for the Mopar exhaust
Old 05-31-2005, 05:12 PM
posthondaremoval's Avatar
posthondaremoval
posthondaremoval is offline
If you are going to stop at stage 2 it will be fine, and add a little power. It will help the car reach its potential with s1 or s2. If you think you'll end up going to s3, think about a 3" exhaust.
Old 06-01-2005, 10:06 AM
black4's Avatar
black4
black4 is offline
you may gain 10 hp tops bu trust me you do feel a differance it was the first mod i did to my car.get above 350 hp then switch to 3inch exhaust.
Old 06-01-2005, 02:00 PM
PSI Chick's Avatar
PSI Chick
PSI Chick is offline
you'll notice the difference top end
Old 06-01-2005, 02:23 PM
Gump's Avatar
Gump
Gump is offline
you get a lot more trq... and it helps with other mods a lot. i think its retarded to build up your engine and leave stock exhaust.
Old 06-02-2005, 06:10 AM
71RoadRunner's Avatar
71RoadRunner
71RoadRunner is offline
I've always heard the numbers thrown around on how much power the Mopar/Borla exhaust is good up to, but Mopar has the 355 horsepower rating on the Stage 3 with 100 octane and the Mopar/Borla exhaust. So it should be good up to 355 horsepower at least.
Here it is straight from Mopar: "The Stage 3 Kit with Turbo Toys in high-octane mode increases power to an amazing 355 hp at 5200 rpm and 365 ft.-lbs. of torque at 3200–4800 rpm! The Mopar Performance Cat-Back Exhaust System (P4510461) is required to obtain these power figures."
Old 06-02-2005, 02:49 PM
posthondaremoval
^^^^^^^^good point, RR - I never looked at it that way.
Old 06-10-2005, 04:00 PM
TurboPowered's Avatar
TurboPowered
TurboPowered is offline
Does anyone have the 02 housing, does it make a big difference from just the mopar catback
Quick Reply: Does Mopar/Catback Exhaust Increase HP?
