Front Drive Shaft Replacement
Old 09-21-2010, 10:23 AM
jakebank's Avatar
jakebank
jakebank is offline
Default Front Drive Shaft Replacement
I have a mangled front drive shaft on my 02 Dakota, the shop quoted me something like a grand for a new shaft and putting it in. I have found a used shaft that is in great shape for $220. I'm just wondering how difficult of a job it is to remove and replace a front driveshaft. I am fairly mechanically inclined, and my father-in-law is as well. Is this a job we can do in the driveway?
Old 09-21-2010, 04:19 PM
Rantz's Avatar
Rantz
Rantz is offline
Most definitely. You'll need wrenches and jack stands to raise the vehicle on. Make sure you inquire to the condition of the replacement shaft. It's important that it isn't banged up and all unbalanced.
The haynes manual has the whole process explained in 9 steps lol
Pick up your haynes manual and it'll walk you through it. As for tips and tricks that might help make the process easier, I'm sure someone will get in here and pipe in if there are any you should know about.
If it's an issue, I can scan that page out of my haynes manual if you really need.
Old 09-21-2010, 10:08 PM
midget-farms's Avatar
midget-farms
midget-farms is offline
Be sure to pick up new CV boots too. They are cheap & its much easier to just cut the old ones to get them off.
You will need to drop the spindle - that is the easy part. The worst part for me was getting the darn nut off the axel so I could take it out of the wheel bearing.
Just remember - take it slow - go one step at a time & keep everything clean. You will have no problems.
Old 09-21-2010, 10:24 PM
magnethead's Avatar
magnethead
magnethead is offline
hard to say if he's talking the half-shaft, or the actual driveshaft between the transfer case and differential. Based on the cost estimate, I'm thinking the latter.
Old 09-21-2010, 11:18 PM
bpark8824's Avatar
bpark8824
bpark8824 is offline
If he is talking actual drive shaft, it's a cake job man. A few bolts on each and shes out. You might need a little PB blaster but in the end it's a real easy job. I just did mine this summer.
Old 09-28-2010, 01:14 AM
Brian2001's Avatar
Brian2001
Brian2001 is offline
well i bought one at a junk yard for like $50 but a new one at autozone will run you about $250. its easy to change. did mine in the driveway. no jack or jack stands!!!!!
Old 09-28-2010, 09:07 AM
thunder98110's Avatar
thunder98110
thunder98110 is offline
im in the process of doing mine right now. easy as hell to do.
https://dodgeforum.com/forum/2nd-gen...experts-2.html
Quick Reply: Front Drive Shaft Replacement
