How to remove rear brake drum. Help Please!
Old 09-17-2010, 02:26 PM
Nando Vazquez's Avatar
Nando Vazquez
Nando Vazquez is offline
Default How to remove rear brake drum. Help Please!
I am trying to remove my rear brake drum to replace a wheel stud but I cant get it off. Ive used plenty of WD40 because I dont have my pbblaster. Ive beat the s*** out of it with a hammer and it still wont budge. Is there any special tool I need or method.
Old 09-17-2010, 02:29 PM
Jr. Mechanic's Avatar
Jr. Mechanic
Jr. Mechanic is offline
Does it move at all, or is it still seized on the axle shaft?
If it isn't moving, you need to take a BFH and hit it on the face of the drum between the lugs, alternating around the drum. Beating the drum from behind isn't doing you any favors.
If it's moving a little, it's hung up on the shoes. You can remove the adjuster plug on the backing plate and use a screw driver to spin the star adjuster to loosen the shoes.
Old 09-17-2010, 02:33 PM
Nando Vazquez
Ive been hitting the face with a hammer like u said but can you tell me more in detail about the star. It moves a little but I cant get it all the way off
Old 09-17-2010, 02:37 PM
Nando Vazquez
I finally got it off I just needed to put some more cajones into it.
Old 09-17-2010, 02:44 PM
Nando Vazquez
Sorry about the mulitiple posting. Computer slowed down so I kept pushing submit.
Old 09-17-2010, 05:47 PM
aim4squirrels's Avatar
aim4squirrels
aim4squirrels is offline
Did you get the drum off, or just the self adjuster?
Old 09-17-2010, 09:51 PM
DukesOfHazzard's Avatar
DukesOfHazzard
DukesOfHazzard is offline
yeah BFH AND SOME PB BLASTER AND SOME *** BEHIND IT. AND MAKE SURE THE E- BRAKE IS OFF...
Old 09-17-2010, 10:34 PM
Laramie1997's Avatar
Laramie1997
Laramie1997 is offline
Another method would be to jack the truck up, take the wheel off, spin one lug nut back onto a stud about half way down, start up the truck, put it in drive, let spin a little bit, and then jab the brakes and see what happens.
Old 09-18-2010, 02:49 AM
Nando Vazquez
I did get the drum off and just put the new 22's on it. Getting the new stud into place was a PITA, I had to use another large nut and a metal brace. I had to tighten the wheel nut till it pulled it into place.
Old 09-19-2010, 04:06 AM
99redram318's Avatar
99redram318
99redram318 is offline
Another trick that works better than pb is coca-cola. Learned that from an audi tech. o2 sensors bolts anything it works better than anything out there. Kinda crazy to think we drnk that stuff!
Quick Reply: How to remove rear brake drum. Help Please!
