Write up: How to reset the Maintenance Required Light
Old 09-16-2010, 06:08 PM
7KINGKAOS7's Avatar
7KINGKAOS7
7KINGKAOS7 is offline
Post Write up: How to reset the Maintenance Required Light
How to reset the "Maintenance Required Light" on a '87-'88 Dodge Dakota
First off lets determine which year dakota has which set-up:
'87-'88 have the "Blue" module below the headlight switch under the dash.
'89-'95 you will need a DRB II scan tool to turn the light off. The dealer should have this and be able to turn it off for you. Or you can buy a scan tool, which isn't cheap...
Now lets know why the light comes on in the 1st place:
(Scanned from my owners manual)
1) Take off the 2 lower dash panels under the steering wheel. 3 screws for the one directly under the steering wheel. And 2 screws for the one nearest to the drivers door.
2) Directly below the headlight switch under the dash you'll see a medium size "Blue" module. Now I've read that some of these modules have a 9v battery in them, which go bad after awhile and need to be replaced. In my case my truck DID NOT have a 9v battery in it.. Where the red arrow is pointing. thats where the 9v battery would be if your truck had one. Now if you look at the picture where the white circle is. Thats the button you need to press. Have the truck running, then use a toothpick or something similar and press the button.
3) Now reattach the panels, and your done, enjoy not having the light on to annoy you!
Now, all this info I gathered is from searching 4 diffirent sites, reading my owners manual, and by resetting the light myself on my '88 Dakota 2wd.
If anyone sees any wrong info. Please correct me. Thanx and enjoy!
~7KINGKAOS7
mike davison (01-06-2020)
Old 09-17-2010, 01:56 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Crazy4x4RT is offline
Nice write up! I'm sure this will help out tons of people. I will post this in the FAQ in this section.
Old 09-17-2010, 02:09 AM
7KINGKAOS7's Avatar
7KINGKAOS7
Thanx! Anything 2 help out the community..
Old 09-17-2010, 02:17 AM
sammatthews2007's Avatar
sammatthews2007
sammatthews2007 is offline
I see you have a vent release lever - what's that for?
Old 09-17-2010, 03:58 AM
7KINGKAOS7's Avatar
7KINGKAOS7
To let air from the outside in or out..
Old 09-17-2010, 07:35 AM
sammatthews2007
Yeah - was just wondering where that vent is. No big deal.
Old 09-17-2010, 08:27 AM
7KINGKAOS7's Avatar
7KINGKAOS7
From my manual: "From below the instrument panel on the drivers side."
Old 09-17-2010, 05:18 PM
kikazzdakota's Avatar
kikazzdakota
kikazzdakota is offline
awesome i need to do this
Old 09-17-2010, 10:51 PM
TNtech's Avatar
TNtech
TNtech is offline
Site Moderator-Dodge Tech
Shew...the good old days
Old 09-18-2010, 06:25 PM
Deerkiller9991's Avatar
Deerkiller9991
Deerkiller9991 is offline
i dont have that blue box, theirs nothing like that in that general area
Quick Reply: Write up: How to reset the Maintenance Required Light
