Power wagon Winch Problems, Changing plugs?
Old 09-13-2010, 01:09 PM
NicPowerwagon's Avatar
NicPowerwagon
NicPowerwagon is offline
Default Power wagon Winch Problems, Changing plugs?
I went to use my winch and its dead, No click from the solenoids nothing. Checked out the battery connections and everything looked A ok.Anyone else had warn winch issues on the Pw? I was also curious About doing the spark plugs 've herd of guys snapping them off in the head and that there a royal B*tch. Im just wondering if there that bad or if this is just bs from guys who couldnt drive a nail in with a sledge hammer. Any input would be greatly appreciated. Thanks
Old 09-13-2010, 01:46 PM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
I has a warn winch but never any issues from it. Could the problem be in the remote?
Old 09-13-2010, 10:48 PM
HammerZ71's Avatar
HammerZ71
HammerZ71 is offline
Three Warns for me over the last 16 years. Never a hint of a problem from any of them. Unless you blew all four solenoids, you should at least get a "click". So my guess would be that you are not getting power to the unit (bad ground maybe). Take you a meter and start checking for where you are losing continuity.
As far as the plugs go, the back two are a b*tch! but do-able...
Old 09-14-2010, 12:23 AM
That1guy's Avatar
That1guy
That1guy is offline
You can call warn. They shouldnt have a problem helping you.
Old 09-14-2010, 08:11 AM
HammerZ71's Avatar
HammerZ71
Also, if you find you need them, I have a source for the solenoids at about 1/4 the price from Warn. PM me and I'll dig it up...
Old 09-15-2010, 02:01 PM
OlDirtyJohn's Avatar
OlDirtyJohn
OlDirtyJohn is offline
damn, sounds like your winch is totally dead. you should just send it to me, to properly dispose of it. ill pay shipping.
Old 09-16-2010, 01:27 PM
HEMISith's Avatar
HEMISith
HEMISith is offline
Have you tried bypassing the thermal protection? Sometimes that prevents the warn winch from working. At another dodge forum, they have a simple bypass installed to prevent this.
Old 09-16-2010, 01:33 PM
HammerZ71's Avatar
HammerZ71
I dunno if I'd try that? I've only worked one of my Warns hard enough (tree clearing for ATV trails up at the farm) to overheat it and have it cut off on me. After a short period of time it cooled off and went right back to pullin'. I'd rather have to give my winch a short "breather" than burn it up...
Old 09-16-2010, 03:38 PM
dirtydog's Avatar
dirtydog
dirtydog is offline
Moderate User
Did you check your fuse for the winch to make sure it is good? it's either in the fuse panel or there might be an inline fuse under the battery tray??
Quick Reply: Power wagon Winch Problems, Changing plugs?
