Engine hesitates, stumbles, pops on acceleration
Old 09-08-2010, 11:13 AM
Maverick17s's Avatar
Maverick17s
Maverick17s is offline
Default Engine hesitates, stumbles, pops on acceleration
Ok, 2001 Ram 1500 5.9 liter 105k miles. It idles fine, I can coast at speed just fine it only happens when I'm accelerating. Engine stumbles so bad it shakes my whole truck. Press the accelerator to the floor and it pops a few times, but it still stumbles. I get above 60 and it acts fine. Seems like I'm down on power alot when accelerating though.
I've been reading these forums for days, found some good info but nothing exactly like my problem. Any help would be great before I drop some money on a mechanic to look at it.
Old 09-08-2010, 11:43 AM
ferguson30's Avatar
ferguson30
ferguson30 is offline
The first thing I'd check is fuel pressure. You can either buy a gauge to check on the fuel rail, or take it to the mechanic to check. Had that same problem & symptoms with my last ram when the pump started going south.
Old 09-08-2010, 11:50 AM
donizer's Avatar
donizer
donizer is offline
check engine light come on? Sounds like what mine was doing when i lost half a plug on number 8
Old 09-08-2010, 12:03 PM
hain84's Avatar
hain84
hain84 is offline
I just went through this with my 05 ram. Seems real similar to what mine was doing. Check your U joints. My rear one was bad and caused the similar problems. Caught mine early before i lost my driveshaft.
Old 09-08-2010, 05:30 PM
zman17's Avatar
zman17
zman17 is offline
Retired Moderator - RIP
Unscrew the pre cat o2 sensor and take it for a quick ride and see if anything changes. And check the codes. Even if there is no CEL.
Old 09-08-2010, 05:34 PM
dodgeboy1979's Avatar
dodgeboy1979
dodgeboy1979 is offline
Plugged Cat? +1 on the o2 sensor.
Old 09-08-2010, 08:12 PM
jdurling's Avatar
jdurling
jdurling is offline
Sounds like what was wrong with my 99. I changed the #1 oxygen sensor and it has run perfect every since. If you have a decent scan tool, you can do a scan of all your sensors at first start up. When cold it showed the sensor as not working but after the O2 sensor heats up it fools the computer into thinking it is working and doesn't throw an engine light. The auto parts guy told me that dodges are horrible for becoming undrivable because of O2 sensors being bad. Hope this helps.
Old 09-08-2010, 08:18 PM
mountainmanejz's Avatar
mountainmanejz
mountainmanejz is offline
Default Have the same problem
94 Ram 1500, 318 (5.2) only mine runs fine in the begining, but as it warms up it does the same missing, coughing, put the pedal down and it just bogs down. It also seems to do it more when it's in overdrive.
Old 09-08-2010, 08:25 PM
Maverick17s
Already changed the plugs, didn't fix nothing. U joints are good. How do you get the O2 Sensor off. I don't have scan tool. I found a wire broken that goes through the firewall directly above the distributor cap, it goes to a canister on the drivers side beneath the front of the battery.
Old 09-08-2010, 08:56 PM
dhvaughan's Avatar
dhvaughan
dhvaughan is offline
gizmo under the battery is cruise control.
unplug o2 sensor connection on top of the trans. you might have to cut the plastic anchor in order to get ahold of the plug. then unscrew sensor with big wrench. be gentle with o2.
i'd check fuel pressure.
Quick Reply: Engine hesitates, stumbles, pops on acceleration
