2005 Dodge Neon SRT-4
Old 08-19-2010, 06:03 PM
blacksunshine05's Avatar
blacksunshine05
blacksunshine05 is offline
Default 2005 Dodge Neon SRT-4
My name is Shane and I have a 2005 Dodge Neon SRT-4.
ENGINE MODS
AGP DELTA 46 TURBO .48 A/R TURBINE HOUSING (4 INCH PORTED SHROUD INLET)
38MM EXTERNAL WASTEGATE
TURBO XS HIGH PERFORMANCE BOOST CONTROLLER
MODERN PERFORMANCE FRONT MOUNT INTERCOOLER
AEM RED SHORT RAM INTAKE
DCR PORTED INTAKE MANIFOLD
MODERN PERFORMANCE 62MM THROTTLE BODY
AGP RETURN LINE KIT
AGP 750CC PLUG AND PLAY INJECTORS
255LPH FUEL PUMP
SCT FLASH TUNE BY AGP
3BAR MAP AND TIP SENSORS
HARD PIPES WITH HKS BOV
AGP OIL ACCUMULATOR
AGP VALVE COVER BREATHER
MSD RED SPARK PLUG WIRES
NGK IRIDIUM SPARK PLUGS ONE DEGREE COLDER
GRANATELLI IGNITION COIL
BWOODY SOLID UPPER AND LOWER MOTOR MOUNTS POWDERCOATED RED
MODERN PERFORMANCE 3 INCH EXHAUST WITH CAT
JMB POWDERCOATED RED VALVE COVER
JMB POWDERCOATED RED PLUG WIRE HEAT SHIELD
JMB POWDERCOATED RED TRANSMISSION COVER
COOLINGMIST METHANOL KIT
WOT BOX
TRANSMISSION MODS
BWOODY TRANSMISSION MOUNT POWDERCOATED RED
AGP BILLET SHIFT SELECTOR
BOOGER SHIFT LINKAGE BUSHINGS
ACT 6-PUCK SPRUNG CLUTCH
EXTERIOR MODS
PAINTED SIDE MIRRORS BLACK TO MATCH THE BODY
PAINTED HOOD SCOOP BLACK TO MATCH THE BODY
SRT NOSTRIL BADGE
PUNISHER FRONT BADGE EMBLEM
BLACK SHORTY ANTENNA
DEPO BLACK HEADLIGHTS
DEPO BLACK LED TAILLIGHTS
CLEAR SIDE MARKER LIGHTS
CLEAR THIRD BRAKE LIGHT
MRR GT-1 HYPERSILVER WHEELS 18 INCH
225/40/18 Y-RATED HANKOOK VENTUS V12 EVO TIRES
BRAKE/SUSPENSION/CHASSIS MODS
SPORTSTOP FRONT/REAR DRILLED AND SLOTTED BRAKE ROTORS
FRONT AND REAR HAWK HPS BRAKE PADS
DC FRONT AND REAR STRUT BARS
BC COILOVERS
INTERIOR MODS
PROPARTS TRIPLE PILLAR GUAGE POD
AEROFORCE DUAL INTERCEPTOR SCAN GAUGE
AEM UEGO DIGITAL AIR/FUEL RATIO WIDEBAND GUAGE
AUTOMETER -30/+30 PSI BOOST GAUGE
MODERN PERFORMANCE POLISHED SHIFTER ****
MOPAR SHORT THROW SHIFTER
SRT-4 (RED) LOGO FLOOR MATS
JENSEN VM9413 DVD RECEIVER
KICKER LIVIN LOUD SOUND SYSTEM INCLUDES:
TWO 1" HIGH-PERFORMANCE NEODYMIUM IP MOUNTED TWEETERS
TWO 6.5" FULL-RANGE 75-WATT FRONT-DOOR SPEAKERS
TWO REAR 90-WATT COAXIALS 6X9"
A TRUNK-MOUNTED 10" SVC 100-WATT SUBWOOFER
DYNO
360whp@5582rpm at 20psi on pump gas
436whp@5957rpm at 22.4psi on pump gas and methanol
Old 08-19-2010, 06:58 PM
dustyloins's Avatar
dustyloins
dustyloins is offline
Hall of Fame Member
Location: Alamosa, Colorado (200 yards from the Rio Grande)
Shane, I think I know you!!!!!!!!! I've posted a few pics of your car as well. WELCOME, son-in-law and kiss my daughter for me!!!!!!
Dusty/Dad/Jim
Old 08-19-2010, 08:50 PM
V8_Jeep_ZJ's Avatar
V8_Jeep_ZJ
V8_Jeep_ZJ is offline
dude that is one awesome looking underhood shot... lovin the pics, any 1/4 mile times?? or 1/8 mile depending on where you live...
Old 08-19-2010, 11:57 PM
blacksunshine05
Dusty/Dad/Jim
Yes sir I will
At 20psi before the car was tuned. My AFRs were around 10.0. The car was basically drowning in fuel. I went 13.2 @ 109mph on street tires. I was able to cut a 1.82 60'. This is slow with this turbo. People have done 12.6 @ 124mph on 24psi and street tires with this turbo. Now that it is tune I wil see on September 18th what it will do on 22psi. I am pretty sure it will be in the 12seconds on street tires at somewhere around 120mph. If I can do 13.2 with the car drowning in fuel, then with it now properly tuned it will move out pretty easy.
Old 08-20-2010, 03:19 AM
V8_Jeep_ZJ's Avatar
V8_Jeep_ZJ
that is great.. props man... props..
12s wouldnt be a stretch at all.. with the correct tune, 12s would be like shifting..
how much spin in the 60' occurred?? lol
are you just reprogramming the factory PCM when you tune, or a programmer, if so, what kinda programmer you running if you dont mind me askin... ill understand if you dont wanna say.. there are some tricks and info i wont give away about the nitrous setup i have.. lol
Old 08-20-2010, 05:13 AM
blacksunshine05
I dont get into full throttle until the top of second gear. Front wheel drive and 400whp dont go good together so first and second gear and pretty much not any good on street tires. I use a SCT tuner with a canned tune by AGP. AGP is the place I bought the turbo from and they gave me a tune that works with all the parts that I have put on my car. I just flash my factory PCM and everything is good.
Old 08-21-2010, 04:34 PM
showsxt's Avatar
showsxt
showsxt is offline
Wow how did i miss your thread. Love your srt4 probably the best and cleanest lookin black srts around. I love all your mods. I sure did not know that dusty was your father in law wow. Kind of cool a son in law and father in law have two of the best lookin srts around.
Old 08-21-2010, 05:32 PM
blacksunshine05
Default Possible Calendar Candidate
The top two pictures are up for a possible election in and SRT calendar. Wont know until November if I made it or not. I will be taking more pictures and see if they pick them also. But thus far they asked me for the top two. More to come.
Shane
Old 09-01-2010, 04:14 PM
blacksunshine05
Car is now lowered on BC coilovers. I had these since May and finally put them in. Pictures of it in first post. You can tell the huge different in height.
Old 09-07-2010, 01:07 PM
membercalendars.com's Avatar
membercalendars.com
membercalendars.com is offline
Former Vendor
ENGINE MODS
AGP RETURN LINE KIT
255LPH FUEL PUMP
AGP OIL ACCUMULATOR
TRANSMISSION MODS
EXTERIOR MODS
SRT NOSTRIL BADGE
BC COILOVERS
INTERIOR MODS
DYNO
Love the pics, especially the first two!
Quick Reply: 2005 Dodge Neon SRT-4
