Brightest headlights???
Old 08-17-2010, 03:43 PM
ccgRAMrod's Avatar
ccgRAMrod
ccgRAMrod is offline
Default Brightest headlights???
I want to put some new headlights in my truck OEM nothing else and no blue lights. I was wondering who makes the brightest factory replacement bulb?
Thanks.
Old 08-17-2010, 03:55 PM
DragonHemi's Avatar
DragonHemi
DragonHemi is offline
I've really like Sylvania Silverstar's in the past, before HID's. They're bright, but nothing compares
Old 08-17-2010, 05:12 PM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
^^^^^ Agreed.
But i would spend the 50-75 and get HIDs.
Old 08-17-2010, 05:23 PM
ccgRAMrod's Avatar
ccgRAMrod
What brand HID?
Old 08-17-2010, 06:06 PM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
Any brand will work. Get a kit off ebay and a set (or two) of 50 watt load resistors from ebay and call it a day.
There are more than a FEW threads on this. Dont take it the wrong way but we get a lot of noobs with HID questions so there is plenty of info out there on it but I will sum it all up for you
Our trucks PCM and FCM read a resistance measurement through the headlight and tail light bulb filaments. When a filament blows the resistance drops and this lets the PCM/FCM know a bulb is out and two things happen here.
1) the modules reduce voltage and
2) the Lamp Out on the dash comes on to notify the driver
So because HIDs are gas filled and not a filament type bulb, when you plug them in the PCM/FCM module does not see "bulbs" and those two things stated above happen.
But because the voltage has been reduced, the HID kits will normally strobe or flicker.
The OEM filament type bulbs are 55w/65w bulbs. One the headlight harness plugs there are three wires. There is the low beam (12v), the high beam (12v) and the common (-).
So my taking 50 watt load resistors and adding them onto the HID harnesses, we can used them to replicate the resistance needed to trick the PCM/FCM into thinking there are bulbs there and that will reciprocate the two issues stated above. In other words, full voltage will be supplied and no Lamp Out light on the dash.
Specifically, the resistors get wired as such. We know there are two ends to each resistor and there are three wires on each headlight. Take one load resistor and splice it to the low beam (12v) wire and the other end to the common (-) wire. The other resistor goes with one end spliced to the high beam (12v) wire and the other to the same common (-) wire.
I think this covers everything.
Old 08-17-2010, 08:05 PM
tsnyder's Avatar
tsnyder
tsnyder is offline
I have had piaa white extreme blue plus 4k in both my rams there a 55w bulb but output is 85w normal beam and 110 highbeam u can get them for rams driving lights also. iv had them for over a year now and they got a 1 year waranty. but pricier than silverstars
Old 08-17-2010, 10:29 PM
bigpappaholt's Avatar
bigpappaholt
bigpappaholt is offline
where do you locate the resistors? i know they can get crazy hot
Old 08-18-2010, 02:32 AM
donjohnk's Avatar
donjohnk
donjohnk is offline
you aint kiddin.. my buddy messed with me and told me to move them off the bumber frame and only had them on for a few seconds.. they stuck to my fingers!
Old 08-18-2010, 06:08 AM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
These are where mine are. They are not around anything else they can touch.
Old 08-18-2010, 08:05 AM
Dunno207's Avatar
Dunno207
Dunno207 is offline
Just get you some 6000K HID's it'll be a bright white. Once you go HIDS you never go back.
Quick Reply: Brightest headlights???
