2 Inch Lift
Old 08-15-2010, 04:33 PM
ajoshi91's Avatar
ajoshi91
ajoshi91 is offline
Default 2 Inch Lift
So a while back i was talking to mrwilliwizard on youtube and he told me he got a 2 inch lift done for 80 bucks.
He did a torsion crank in the front and a rear shackle lift in the back.
I wanna do this as well. And I'm not much of a mechanic but i think i can do this project myself.
My question is, is this difficult to do? also where are the torsion bar's bolts located so i can give them a few cranks?
Also is this a sturdy lift? i don't want my durango falling apart because its a bad way to do a lift or because i did it wrong.
what do you guys think?
Old 08-15-2010, 04:40 PM
shrpshtr325's Avatar
shrpshtr325
shrpshtr325 is offline
THE ULTI-MOD
it is a perfectly acceptable way to lift the truck and will hold up, the torsion bar bolts are on the frame back from the wheels, just follow the t-bars and you will find the bolts, and as long as you have some patience, and the right tools you shouldnt have too much trouble doing this job
ajoshi91's Avatar
ajoshi91
ajoshi91 is offline
Default Torsion/shackle 2 inch lift
Also will i need a realignment for my tires afterward?
Old 08-15-2010, 04:44 PM
ajoshi91's Avatar
ajoshi91
ajoshi91 is offline
How far back from the wheels are the torsion bar bolts? if i start from the frame connecting to the front wheel and move inwards how far inwards am i going? 1-2 ft? also is it the only large bolt there? don't want to get it confused with something else.
I was just under my truck and found two possible bolts. the one i think it is, is facing directly towards the ground and is a tad further towards the front of the truck off the frame from the wheels. is this correct? Anyone have a picture of the torsion bar bolt and ots surroundings so i can get a good look at it?
also this just hit me now. I'm in a state where we have 5-6 months of snow (Minnesota) and there is a lot of rust on the bolts will this give me a problem? or will WD-40/liquid wrench take care of this?
Old 08-15-2010, 05:04 PM
shrpshtr325
THE ULTI-MOD
wd40 SHOULD take care of the rust just fine, its not IN it is BACK, follow the frame back and see where it and the T-bars meet, should be the only bolt there
and yes it will need to be aligned whenever you touch the front suspension (except for shocks, they dont require alignment )
Old 08-15-2010, 05:08 PM
ajoshi91's Avatar
ajoshi91
ajoshi91 is offline
so its a little further towards the rear of the car? just a little bit from where the wheels are? i'll go take another look. and i'm assuming these are gonna be large 5/8-3/4 inch by 6 inch bolts? not some small thin little ones with small hex heads?
Old 08-15-2010, 06:06 PM
shrpshtr325
THE ULTI-MOD
you would be correct (im not sure on the size, but they are bigger than most)
Old 08-15-2010, 07:50 PM
ajoshi91's Avatar
ajoshi91
ajoshi91 is offline
Alright thanks man! I'm gonna go take another look under my truck. I'll try to take a video or a couple pictures of it underneath there and I'll post it to this thread. then you guys can tell me if i found it.
I don't know if i will be able to do it tonight though. possibly tomorrow morning. or else I'll make a fresh thread for it.
thanks man, appreciate it!
Old 08-15-2010, 08:43 PM
hydrashocker's Avatar
hydrashocker
hydrashocker is offline
Old 08-16-2010, 12:17 PM
ajoshi91's Avatar
ajoshi91
ajoshi91 is offline
You can always count on hydrashocker to find you a link to a page where your question is being answered!
Quick Reply: 2 Inch Lift
