04 RAM 2500 4x4 ABS pump wont shut off!
Old 08-06-2010, 04:12 PM
04MOPAR's Avatar
04MOPAR
04MOPAR is offline
Default 04 RAM 2500 4x4 ABS pump wont shut off!
SO I get in my truck and while im driving I notice the ABS light and brake dashlight is on, I can also hear the ABS pump running. I turned off the truck but the pump still runs, thought It might reset itself or something but no luck.. I had to pull the 40A fuse to get it to stop. Anyone know what could cause this?
Old 08-07-2010, 02:17 PM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
We would really have to look at the schematics involved with that to see what all controls it. It could be a relay with welded contacts or a bad pump.
Old 08-07-2010, 07:44 PM
Gone Fishin's Avatar
Gone Fishin
Gone Fishin is offline
I'd almost lay odds its a welded relay, the ones used in our trucks are junk
Old 09-27-2010, 04:58 PM
OldTarFour's Avatar
OldTarFour
OldTarFour is offline
I have the same problem on my 05 2500. Did you ever come up with a solution?
Where is the relay that I should look for?
Old 09-27-2010, 07:53 PM
CBR900RR19's Avatar
CBR900RR19
CBR900RR19 is offline
I own a 2004 Dodge Ram 1500 Laramie 5.7-liter HEMI Magnum and checked the FSM looking for a relay I don't believe there is one. (Could be wrong happened once before LOL) I see two fuses 6 and 35 for the ABS module. But anyway I had this problem on my 2nd Gen so I believe your problem is the ABS Module itself. You say the pump stays running right? There is a simple ABS wizard on the site as well you could use or you could call them they are extremely helpful. But I would just pull it and send it to Module Masters. http://www.modulemaster.com/en/index.php
I sent them mine to rebuild they warranty it for 5yrs and I had it back in 3 days with new bolts all for 153.00. They were one of the best companies I have ever dealt with.
Size:  30.2 KBName:  2004ABSa.jpg
Last edited by CBR900RR19; 09-27-2010 at 07:56 PM. Reason: Images were in the middle of text
Quick Reply: 04 RAM 2500 4x4 ABS pump wont shut off!
