how do i remove rear drive shaft - please answer kinda quick
Old 05-22-2005, 01:29 PM
zeekxxx's Avatar
zeekxxx
zeekxxx is offline
Default how do i remove rear drive shaft - please answer kinda quick
I am removing the rear shaft and after I pull the 4 bolts its just sitting there. DO I need to wack the hell out of it for it so slide off the rear dif?
Old 05-22-2005, 01:33 PM
BadStratRT's Avatar
BadStratRT
BadStratRT is offline
The Forum Tyrant
Default RE: how do i remove rear drive shaft - please answer kinda quick
do you mean the axles?
Old 05-22-2005, 01:35 PM
zeekxxx's Avatar
zeekxxx
zeekxxx is offline
yes sorry rear drive shaft from the trans to the rear diferential.
Got the rear 4 bolts out of the drive shaft but the shaft wont come off the differential. Wondering if i missed something or is the rust holding it up. With the 4 bolts gone the drive shaft should just drop down and thats that.
thx
Old 05-22-2005, 01:40 PM
steve05ram360's Avatar
steve05ram360
steve05ram360 is offline
after you pull the u-bolts out and the caps off, it should just come right out. give it a little upward pressure and it'll pop loose. It's not pressed in or anything.
Old 05-22-2005, 01:46 PM
zeekxxx's Avatar
zeekxxx
zeekxxx is offline
Ill try that.
I wish autozone whould have had the damn repair manual when I placed my order last month.
They were out.
thx
Old 05-22-2005, 02:20 PM
zeekxxx's Avatar
zeekxxx
zeekxxx is offline
Sweet I got it out.
The problem was the truck was on a slight hill and the rear axle was putting some pressure on the driveshaft.
I had to block the front wheels and use my floor jack to raise the rear pumpkin.
After the tension was off the driveshaft a sharp wack on the shaft and it fell down.
I was just worried I was missing something when my first couple wacks did nada.
Anyhow thx steve
Old 05-23-2005, 01:40 PM
steve05ram360
oh man, hope you didnt wack it too hard, it's balanced... usually if you wiggle it a bit it'll break free... did you get it all back together? Why did you pull it?
Old 05-23-2005, 09:24 PM
zeekxxx's Avatar
zeekxxx
zeekxxx is offline
u joints squeaking they were shot. And I used a rubber mallet.
Quick Reply: how do i remove rear drive shaft - please answer kinda quick
