Dead Battery, now wont Idle
Old 07-24-2010, 01:45 AM
WCV97's Avatar
WCV97
WCV97 is offline
Default Dead Battery, now wont Idle
hey guys,
I killed my battery today playing the radio while removing and repairing the rear window (the plastic thing that holds the two cable ends in broke)
back to the main problem... I killed the battery, charged it back up and now the D stalls while at idle or when I pull up to a stop light, hell... it even stalled once when I slowed down to make a sharp corner
Any Idea's??????
Old 07-24-2010, 10:20 AM
redfernclan's Avatar
redfernclan
redfernclan is offline
Old dead battery that is not keeping a charge. Mine did the same thing. Went to start it one day and it turned over very slow but started. It ran but would not idle. Kept the RPMs up to charge the battery for about five minutes and then it would idle. Put the charger on the battery after shutting it off and it would not play at all. New battery and all is better.
Old 07-24-2010, 10:21 AM
shrpshtr325's Avatar
shrpshtr325
shrpshtr325 is offline
THE ULTI-MOD
put a new battery in it, these trucks are VERY particular about the battery being good and strong, even a slightly weak battery that would run fine in most cars will cause this problem in the Durangos
Old 07-24-2010, 10:49 AM
1999_Durango_SLT's Avatar
1999_Durango_SLT
1999_Durango_SLT is offline
I had this too but after a new battery and a new Alternator, Then found out the fuse 140 amp that's in the fusebox under the hood blew somehow? Well couldn't find another 140 so I put a 120 amp in it. Figured it'll be okay since the alternator is only pushing 117 amps. Still looking for a 140 amp fuse though Might be your issue too might not just thought this is worth a share.
Old 07-24-2010, 10:57 AM
dhvaughan's Avatar
dhvaughan
dhvaughan is offline
charge or replace battery. then reset pcm. it'll straighten itself out.
Old 07-24-2010, 12:30 PM
WCV97's Avatar
WCV97
WCV97 is offline
done recharged the battery, whats the best way to reset the PCM?
Old 07-24-2010, 12:38 PM
thorze's Avatar
thorze
thorze is offline
Best way I know is to disconnect the neg batt cable and then turn the key to start and hold for 30 seconds.
HTH and Good luck!
Old 07-24-2010, 01:50 PM
hydrashocker's Avatar
hydrashocker
hydrashocker is offline
At the top of this thread explains it all: https://dodgeforum.com/forum/1st-gen...ine-light.html
Low or bad battery's cause all sorts of issues so you might just wanna replace it.
Quick Reply: Dead Battery, now wont Idle
