Consensus on Fuel Pump replacement - drop tank or lift bed?
Old 07-23-2010, 03:43 PM
16Victor's Avatar
16Victor
16Victor is offline
Default Consensus on Fuel Pump replacement - drop tank or lift bed?
Videos and posts say to lift the bed to replace the fuel pump. Mechanic friend says he'd drop the tank. If you've BTDT, what would you tell me to do?
216,000 miles, not as rusty underneath as I'd have guessed....
Thanks,
Ron
Old 07-23-2010, 04:16 PM
issakar's Avatar
issakar
issakar is offline
Thanks,
Ron
D00d,
BTDT, LIFT THE BED. lol. I by no means am that good when it comes to repairs since I am still learning, and when we worked on the fuel pump we lifted the bed. 8 bolts, 3 screws, an electrical harness connector and it's ready to come off.
Old 07-23-2010, 04:48 PM
pashadowops's Avatar
pashadowops
pashadowops is offline
I dunno man, I guess if I had to do it all over again, I would take the amount of gas in the tank into consideration. I had just filled the tank when mine went. What a PITA getting the gas out and into containers. 20 some gallons of gas is more than you would think. If I took that into consideration, I probably would have lifted the bed. On the other hand, if there is very little or no gas in the tank, it's not that bad to remove the tank, do the pump and put it back up. When it comes down to it I guess it's your call. Good luck, I am doing a fuel pump in my kids Saturn tonight. Same thing, a freshly full tank of gas, only this time I bought a power siphon to pump the gas into my truck, then I will drop the tank hehe.
Old 07-23-2010, 07:38 PM
shadowthedakota's Avatar
shadowthedakota
shadowthedakota is offline
its just easier to lift the bed off and avoid the rusty eyes. unless you have minimal rust and low gas in the tank.
Old 07-23-2010, 09:55 PM
tmacdakota's Avatar
tmacdakota
tmacdakota is offline
If you have an impact wrench, pneumatic or electric, it's easier to spin the bed bolts off...even if you're alone. Then you scoot the bed back, replace the pump and reverse the procedure. I hate laying on my back fighting rusty, stuck fasteners like those on the tank straps. Just keep the bed fairly square if decide not to lift it off, then you just have to scoot it back in place after you finish the pump.
Old 07-24-2010, 01:57 AM
bp4131017's Avatar
bp4131017
bp4131017 is offline
It's not dropping the tank down that's the bitch... it's dealing with rusty/broken straps and then also trying to get it back in when you magically lost what feels like 2 inches on the straps. I've never lifted the bed, but I F-ing hate dropping them
Old 07-24-2010, 03:18 AM
LO 619's Avatar
LO 619
LO 619 is offline
you should always be wearing safety glasses when working underneath a vehicle, rust shouldn't come into play.
Old 07-24-2010, 05:14 AM
Joezilla64's Avatar
Joezilla64
Joezilla64 is offline
Lift the bed. It will make it much easier.
Old 07-24-2010, 09:36 AM
16Victor's Avatar
16Victor
16Victor is offline
http://home.fuse.net/pieper/2010-07-24%2008.55.46.jpg
Thanks for the replies, lifted the bed, job done in 90 minutes, decided to do rear shocks at the same time, too easy with the bed off.
Thanks again,
Ron
Old 07-24-2010, 01:08 PM
kahanabob's Avatar
kahanabob
kahanabob is offline
what did you do with the filler tube? does it just remain sticking up in the position it was attched to the filler door?
Quick Reply: Consensus on Fuel Pump replacement - drop tank or lift bed?
