99 Durango, new PCM still stalls
Ok, here goes. I bought my Durango back in March. It ran fine. Now when I sit and idle for 5-10 minutes it dies. It done this while driving down the road the first time. The odometer read "NOBUS". I bought a new PCM took it to Dodge and had it flashed. Now it is doing the same thing except the "NOBUS" doesn't read in the odometer unless you just turn the key forward without trying to actually start it. It will blink the odometer reading 4 times and then read "NOBUS". This is starting to be a huge problem. I don't have the money to keep just throwing at random parts in hopes that it will fix the problem. Any ideas and suggestions would be greatly appreciated. Thanks in advance for any help.
when you say you bought a new PCM and then had it flashed...does this mean you bought a refurbed PCM or is this something directly from the Dodge dealer and is OEM or what...??
its true that stalling can be due to the PCM - my 99 had this and so do many people after about 5 years for the 99 year, but it must be replaced with a brand new one from Dodge if you want to be belt and braces
Chris
Chris
