2003 Neon speedometer and tach problems
Old 07-08-2010, 03:55 PM
ala650le's Avatar
ala650le
ala650le is offline
Default 2003 Neon speedometer and tach problems
On my wife 2003 Neon, she left the light on and had to get a battery she took the car to Autozone and they changed out the battery. She left and the speedometer or the tach didn't work. I come in from work and looked at the car what i found was the speedometer and tach had went all the way around to the peg and will not come back to zero. Is there any thing I can do?
Old 07-08-2010, 07:29 PM
darthroush's Avatar
darthroush
darthroush is offline
Section Moderator
I believe the procedure is: hold the trip button down for a few seconds, then turn the key to the "ON" position (not start), and the needles should sweep and reset.
Old 07-09-2010, 09:13 AM
ala650le's Avatar
ala650le
ala650le is offline
Thank you very much
Old 06-14-2011, 05:47 PM
target29's Avatar
target29
target29 is offline
Thank you very much! Saved me lots of $$$$$$ witha really simple fix!
Old 07-23-2018, 04:07 AM
Barry Guy's Avatar
Barry Guy
Barry Guy is offline
Default Speedometer and tach not working.
I read the article on how to reset the speedometer and tach at 3:00am. I got up and took my keys and done exactly what it said to do. To my surprise, they started working again. Thank you so much for your help. Sincerely, Barry.
Old 08-26-2021, 05:17 PM
luckyluka1's Avatar
luckyluka1
luckyluka1 is offline
Default Same problem with same year Neon
Thanks for the tip. My battery went dead and I put the charger on it for a few hours, then when I started it and went to drive it, both speedometer and tachometer were pegged. This worked like a charm. Thank you very much!
Quick Reply: 2003 Neon speedometer and tach problems
