help changing front brake pads on 2006
Old 07-06-2010, 06:51 PM
patrapper's Avatar
patrapper
patrapper is offline
Default help changing front brake pads on 2006
first time changing front brake pads on my 2006 1500 Ram and it doesn't seem as straight forward as I am use to.
after I loosen the caliper bolts I usually am able to pull them out (on other vehicles I have owned)
on the Ram they wont come out and there seems to be a nut behind the the mounting bracket that spins with the bolt and prevents me from removing it
any thoughts as to what I am doing wrong
Old 07-06-2010, 06:59 PM
bello926's Avatar
bello926
bello926 is offline
grab a pair of channel locks and hold it then loosen the bolt it will come right off
dirtydog's Avatar
dirtydog
dirtydog is offline
Moderate User
Maybe THIS will help?
*changed link..
Old 07-06-2010, 07:00 PM
brettj2408's Avatar
brettj2408
brettj2408 is offline
they tend to do that sometimes. i take a pliers and clamp over the rubber piece while it spins lightly not to rip the boot or slide it back. then loosen them.
they are just 2 normal pins
Old 07-06-2010, 07:06 PM
patrapper's Avatar
patrapper
ok headed back out to try
dirtydog the link says I do not have permission to view the page
Old 07-06-2010, 07:23 PM
Dunno207's Avatar
Dunno207
Dunno207 is offline
All I had to do is take the 2 bolts of on the back of the caliper, then take a flathead and pop the middle piece up. Slide new ones on compress the caliper and put on.
Old 07-06-2010, 10:16 PM
patrapper's Avatar
patrapper
good to go! thanks guys
once I figured out the caliper bolts are only an inch or so long and threaded into the nut behind the caliper mounting bracket I got it
rotors ready to go get turned down tomorrow morning
Quick Reply: help changing front brake pads on 2006
