Old 08-06-2015, 02:56 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Electrical System
Print Wikipost
How can I reset the check engine light?
Old 07-06-2010, 10:15 AM
bigaussie's Avatar
bigaussie
bigaussie is offline
Default How can I reset the check engine light?
2000 Dodge Intrepid ES, 3.2 - had P0302 code, changed out the wire/ignition coil/spark plug & things are back to normal - now how do I set the check engine light? Since the battery is in such a difficult location, don't want to go that route if I don't have to...
Old 07-06-2010, 10:13 PM
penco8's Avatar
penco8
penco8 is offline
just disconect the ground cable... you dont have to disconnect the batterrey cable... you should have the jump start on top just disconnect the neggative cable mfor aleast 10 min hope this help
Old 07-14-2010, 11:16 AM
bigaussie's Avatar
bigaussie
Default Thanks!
Worked like a charm!
Old 07-14-2010, 11:37 PM
penco8's Avatar
penco8
penco8 is offline
aight good
Old 07-18-2010, 10:05 PM
torsiondrummer's Avatar
torsiondrummer
torsiondrummer is offline
I've tried this several times, it keeps coming back. Although its just over 97K miles, what else could cause the check engine light? She runs ok, just always had the light- any ideas?
Old 07-24-2010, 02:18 PM
June bug's Avatar
June bug
June bug is offline
Just removing the negative cable to clear codes might lead to other problems. Yes, the code will clear but if there is a real issue with the car the light will just come back on. Anoher issue with removing the negative cable is that there is some risk of losing stored data, ex. Transmission. Requiring a "Flash" to operate. I found out the hard way on an 2002.
Old 07-24-2010, 02:46 PM
sapporo's Avatar
sapporo
sapporo is offline
huh? how would you expect to install a new battery without disconnecting, or what if your battery goes dead and you jump start. I've never needed any kind of "flash" after replacing, disconnection or recharging any battery. :?
Old 07-24-2010, 04:37 PM
penco8's Avatar
penco8
penco8 is offline
lol are nyou serious where did you learn that??? just wondering???
Old 07-25-2010, 09:03 AM
June bug's Avatar
June bug
June bug is offline
Must be getting old.... I read one thing and was thinking of another thread I had read eariler. Everyone get back to work. lol
Old 07-25-2010, 11:42 AM
sapporo's Avatar
sapporo
sapporo is offline
it sure looks like you were VERY specific to answering this exact post with removing neg cable and then needing to flash computers just like the problem you had with a 2002.
so please explain the exact problem you had with your 2002 and how that related to the battery problem? I'd like to learn about this scenario to improve my knowledge
Quick Reply: How can I reset the check engine light?
