Need help - Slow starts, misfire codes on 2004 5.7 hemi
I need some help troubleshooting multi cylinder misfire alarms and slow starts on a 2004 Ram 1500, 5.7 hemi, 44,000. Here are some details: Historically, truck cranks for a few seconds before firing up (typicaly between 2 - 5 seconds), changed to platinum plugs at 30,000. Misfire codes have been intermitent, multicylinder and sometime individual cylinders. The eng light appears to come in immediately after the engine fires up after a slow start. I have observed no rough idle or rough engine performance at highway speeds and MPG is as expected 15.5 for short trip driving and 21 or slightly higher for continuous highway driving. I ran 4 cans of Seaform through the fuel system to ensure it was clean with no apparent affect. Dealer cleaned engine carbon with a spray cleaner and updated flash menory which did not resolve problem. I am thinking the misfiring is during the slow starts. Any help to focus my troubleshooting in the right would be appreciated.
A lot of guys dont like using plat plugs in thier truck. it could be a cam positioning sensor on the way out.
If the engine light is coming on then you should try to go some place like Autozone and let then scan for the OBD codes and bring them back here and tell us what they are so we can help you more.
The current DTC code is 0300 Random multiple cylinder misfires detected. I have gotten this code several times in the past along with misfire codes for a few specific cylinders. A defective cam or crank positioning sensor was something I had thought about. Also, I had thought about the fuel pressure bleeding down with the engine shutdown.
It turns out my problem was a leaking fuel injector. I purchased a fuel pressure gauge and noticed that when I turned the ignition from ON to OFF, the fuel pressure would drop fairly quickly. I then knew either an injector was leaking or the pressure was bleeding back through the fuel pump/check valve. I figured out a way to determine If the problem was a leaking injector. After priming the system to operating pressure which is 60 PSI for this vehicle, I quickly bled down the pressure using the pressure gauge bleed valve. This allowed the pressure to bleed down before fuel had a chance to leak through a leaking injector. I found that when I quickly bled off the pressure and waited a few hours, the engine would immediately start as it should - it was obviously not flooded. Knowing that the problem was a leaking injector, I purchased a new injector and obtained instructions for injector replacement. After removing the injector & plug wires, I removed the left side 4 injectors together without having to remove the fuel line. With the injectors out of the intake, I pressurized the fuel rail by turning the ignition to ON - and immediately noticed one injector started dripping fuel. I replaced the leaking injector and my truck now starts as it should and there are no misfire alarms.
the hemi will preform the same on copper or platinum, so its basically do you want to pay $1.50 a plug or $25 a plug and you need 16. copper is oem and is what the engine is designed to run
