License plate light problem
Old 07-02-2010, 10:17 AM
hometheaterman's Avatar
hometheaterman
hometheaterman is offline
Default License plate light problem
So when my license plate light bulbs died, I went to change them and it seemed like the plug wasn't clipped into the light socket or anything. Almost as if it was glued in there. Of course when I removed the plug from the actual socket I can't put it back in and get it to stay as there doesn't appear to be anything for it to hook onto. What's the best way to fix this? What's the proper way to change these things?
Old 07-02-2010, 10:34 AM
dsertdog56's Avatar
dsertdog56
dsertdog56 is offline
License lights have a one piece mount made of a white plastic material. Over time, the heat from the bulb deteriorates the plastic and the socket part separates from the mount.
Perhaps someone else has effectively repaired the break but I've tried bubba glues, super epoxies and even gas tank repair guck. The heat from the bulb simply breaks them down in a matter of weeks.
You will have to replace the wiring harness which A. is a DWO part and B. it means the other side will also fall apart soon.
You must be blessed...I've replaced the harnesses on both sides at least twice since I've owned my truck. Whatever you do, don't run brighter(hotter) bulbs, it only accelerates the deterioration.
Old 07-02-2010, 10:58 AM
hometheaterman
So where can I get these harnesses? What's DWO btw? This is the crappiest licesne plate light setup I've ever seen. Then again, I guess it's what I should expect from a Dodge. I need to replace both sides.
Old 07-02-2010, 11:03 AM
hometheaterman
So I see online on Dodge OEM sites a wiring harness, a socket that says lamp wiring, etc. Which one of these do I need? Do I need the housing too?
Old 07-02-2010, 11:07 AM
PurplDodge's Avatar
PurplDodge
PurplDodge is offline
YOu can get them from the dealer for <$30.
Old 07-02-2010, 11:08 AM
03neonSE's Avatar
03neonSE
03neonSE is offline
Those come individualy(sp), behind the bumper you will see theres a connector for both sockets. You can get them at Mopar. They do still make them.
Old 07-02-2010, 11:31 AM
Sheriff420's Avatar
Sheriff420
Sheriff420 is offline
I just unplugged mine and took them out because they both fell out of the bumper.
You can get them from LMCTruck for 16$ each.
I called the dealer and they said $30ish each and that was another one of those hang up on the parts department moments.
Old 07-02-2010, 12:12 PM
hometheaterman
I looked on LMC and they do have them for $16.95 or something. Then it was $10 something in shipping, plus I have to wait for them to come. So I ended up calling the dealer. Turns out they have them for $19 and they are in stock. So when I factor in shipping with LMC the dealer is actually cheaper. So I'm just going to get them there and I can get them today.
Old 07-02-2010, 12:22 PM
Cheat's Avatar
Cheat
Cheat is offline
If it where me, I would take thoughs bulbs out and replace with there led match. You can order them from many websites. http://www.superbrightleds.com/
They should have them....
Old 07-02-2010, 12:43 PM
Sheriff420's Avatar
Sheriff420
I've thought of the LED screws to replace the screws that hold the plate on. I think it was on this site that I saw them.
Quick Reply: License plate light problem
