1995 Dakota V6 3.9 - Rough Idle + Occasional Stalling
Old 07-02-2010, 08:22 AM
natedbrbr's Avatar
natedbrbr
natedbrbr is offline
Default 1995 Dakota V6 3.9 - Rough Idle + Occasional Stalling
I have a 1995 Dodge Dakota V6 that is giving me a difficult time. It's idling rough and occasionally when I'm stopped (at a traffic light for example) and go to step on the accelerator it stalls. Starts right back up and runs fine (excluding the rough idle). It was having a more persistent issue with stalling which I fixed - here is the list of things I've done to try fixing this:
- Replaced MAP Sensor (had a code for this - was the cause of the persistent stalling issue I mentioned).
- Replaced Distributor Cap, Rotor, Spark Plug Wires and Plugs
- Replaced EGR Valve (had a code for this too)
- Replaced Idle Air Control Valve
- Replaced Throttle Position Sensor
At WOT it runs and sounds great. I've sprayed carb cleaner to check the vacuum lines for leaks and haven't been able to find anything. Anyone have an idea what else I might check?
Old 07-02-2010, 09:13 AM
Auron's Avatar
Auron
Auron is offline
pcv valve its a little blue thing on the pass. side of the engine
Old 07-02-2010, 09:31 AM
natedbrbr's Avatar
natedbrbr
I knew I was going to forget something on my list - I also replaced the PCV valve and the Crankcase breather filter.
Old 07-02-2010, 11:42 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Crazy4x4RT is offline
Could be anything. Sounds like a vacuum leak to me.
Old 07-02-2010, 11:36 PM
asosnoff's Avatar
asosnoff
asosnoff is offline
crank position sensor
Old 07-03-2010, 12:33 AM
MagnumMan3.9's Avatar
MagnumMan3.9
MagnumMan3.9 is offline
Besides all of those things named above, it could also be that your computer needs to be cleared by unplugging the positive + battery terminal and letting it sit like that for 15+ minutes then plugging it back in. It could also be that even though you have a new rotor, sometimes that metal piece on the plastic rotor becomes bent to the side and is not centered under the pin on the bottom side of the distributer cap which can cause misfiring which I've had happen to me on my Dakota this time last year. Could also be the ignition timing, I would have someone with a known working timing light check your engines timing. I say known working since my one mechanic had to check my timing a couple weeks ago and his timing light was not working right so he couldn't even get an accurate reading.
Well good luck and please keep us updated on your progress!
Old 12-29-2011, 07:07 PM
MoparMan1995's Avatar
MoparMan1995
MoparMan1995 is offline
Hi I'm having the same problem you are. Did you ever get it fixed? I'd love to know how to fix this problem. It's getting very irritating. Sometimes It will stall in traffic and I can't keep it running and it might take 5-10 minutes till I can shift it just right and slam on the throttle so it doesn't stall so I can drive off.
Old 12-29-2011, 07:24 PM
RockGuardedDak's Avatar
RockGuardedDak
RockGuardedDak is offline
You can't change the timing on these trucks ('92 and up, not sure about previous years). It's all controlled by the PCM. If you try changing the timing by advancing or retarding the distributor, all you are doing is changing the fuel sync, not the timing!
Quick Reply: 1995 Dakota V6 3.9 - Rough Idle + Occasional Stalling
