2nd Gen Durango 2004 - 2009
Low Side Service Port
Old 06-28-2010, 01:07 PM
01ssreda4's Avatar
01ssreda4
01ssreda4 is offline
Default Low Side Service Port
Does this exist on Durangos??? I hunted under the hood the other day and didnt see it. I did however see the high pressure side.
Old 06-29-2010, 01:44 AM
IndyDurango's Avatar
IndyDurango
IndyDurango is offline
Yes, both high and low
Old 06-29-2010, 01:46 AM
01ssreda4's Avatar
01ssreda4
do you know the location?
Old 08-06-2010, 12:51 AM
01ssreda4's Avatar
01ssreda4
Bump this, can anyone tell me the location?
Old 08-06-2010, 07:23 AM
1969CoronetR/T's Avatar
1969CoronetR/T
1969CoronetR/T is offline
vaffanculo
Old 08-07-2010, 05:03 PM
01ssreda4's Avatar
01ssreda4
^^^That link is crap. Just say you dont know or don't post at all.
Old 08-07-2010, 09:07 PM
1969CoronetR/T
vaffanculo
http://www.ehow.com/how_4454107_rech...eon-dodge.html
Try this link and THIS IS A QUESS AS I AM TRYING TO HELP YOU even of it is detrimental to your situation,
FF
Old 08-08-2010, 09:36 PM
IndyDurango
LOL @ U.
Here the forum moderator is personally trying to help and you bite the hands that feeds. That's quality right there.
Good luck on your vehicle. Your resources are getting smaller with each of your posts.
Old 08-08-2010, 11:07 PM
master tech's Avatar
master tech
master tech is offline
Site Moderator & Tech
01ssreda4
Here is what believe you are looking.I also wanted to write to that you can not treat any member on the open forum like that.They are trying to help you.Now that you have the information that you needed.Its up to you responded on the members that you just gave a hard time to,By saying you are sorry on open forum or send each member a pm telling them you are sorry. Thats what real members would do..
DESCRIPTION
Two refrigerant system service ports are used to recover/recycle/evacuate/charge and test the A/C refrigerant system. Unique sizes are used on the service ports for the R-134a refrigerant system to ensure the system is not accidentally contaminated with R-12 refrigerant or service equipment used for R-12 refrigerant.
The high side service port (5) is located on the liquid line (3) above the receiver/drier (2). The low side service port (6) is located on the suction line (9) at the top of the engine. Both the high side and low side A/C service port valve cores are serviceable.
Each of the service ports has a threaded plastic protective cap installed over it from the factory. After servicing the refrigerant system, always reinstall both of the service port caps.
Old 08-09-2010, 08:28 PM
sbtadt's Avatar
sbtadt
sbtadt is offline
open the hood it right in front
Quick Reply: Low Side Service Port
