Old 08-05-2015, 12:19 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: General Overview
Print Wikipost
Help with Dash Warning Lights
Old 06-28-2010, 09:32 AM
yzinger's Avatar
yzinger
yzinger is offline
Default Help with Dash Warning Lights
Hey guys, I have the following three lights on all the time.
ABS
(P)
...I do not see where this 95 1500 4X4 has ABS, secondly, what is the (!) one?, third, why is the parking brake light on, rather, how might i diagnose these and get them to turn off.
Thanks
Brad
Old 06-28-2010, 10:07 AM
mrfarrell's Avatar
mrfarrell
mrfarrell is offline
means you have an abs fault somewhere in the system..the !P is just dodges symbol for your park brake is on..and95 did come with an abs option..does your speedometer work correctly at slow speeds?
Old 06-28-2010, 10:17 AM
yzinger's Avatar
yzinger
yzinger is offline
yeah, i did do a lil homework and yes speedo works fine...
Old 06-28-2010, 10:26 AM
Received 3,164 Likes on 2,918 Posts
Make sure the parking brake is fully released.
Probably the wheel speed sensor in the rear axle went belly up. (although, I would make sure the parking brake isn't causing the other problems first....)
Old 06-28-2010, 10:32 AM
yzinger's Avatar
yzinger
yzinger is offline
fair enough, how do i change this speed sensor?
Old 06-28-2010, 10:45 AM
One or two bolts, and an electrical connector. Sits right on top of the rear differential.
Old 06-28-2010, 11:03 AM
BigRedRam95's Avatar
BigRedRam95
BigRedRam95 is offline
My 95 has ABS but for my e-brake it just says (brake)
Old 06-30-2010, 09:34 AM
yzinger's Avatar
yzinger
yzinger is offline
hey guys, how can i be sure parking brake is releasing ok...i mean, the cable seems to release but perhaps the shoes are not really releasing enough...or, its the sensor...but, i thought the sensor would make the speedo act also..
Thanks
B
Old 06-30-2010, 09:36 AM
There should be a switch located on the e-brake pedal mechanism, that tells the truck the e-brake is applied. (and turns on the light in the dash) Might have to do some serious convolutions to be able to see it.......
Old 06-30-2010, 09:40 AM
yzinger's Avatar
yzinger
yzinger is offline
thanks alot....i will check it out but, i reckon it is not the issue as I made sure the pedal released all the way.
Quick Reply: Help with Dash Warning Lights
