wire diagram for driver window switch
Old 06-27-2010, 01:36 PM
kx250frider617's Avatar
kx250frider617
kx250frider617 is offline
Default wire diagram for driver window switch
I've had the problem where all my window switches don't work except for the driver side even the passenger window. first, can someone tell me if the child lock, locks the passenger window also. second, does anyone have a wire diagram wire I can solder some wires and by pass the child lock because I really don't need it and never will. It's embarrassing when girls gotta ask for permission to roll down their window haha.
Old 06-28-2010, 10:23 AM
MongoDV8's Avatar
MongoDV8
MongoDV8 is offline
Not to sure about the child locks because I don't think I have them. The switch issue is a common problem. Mine did it and I could pop the driver side switch out and disconnect/reconnect the wiring harness and it would start working.
Old 06-28-2010, 10:27 AM
brettj2408's Avatar
brettj2408
brettj2408 is offline
the child locks have no refernce to the window. your drivers switch on your panel will have a window lock and make sure it is off.
Old 06-28-2010, 10:30 AM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
The lockout switch will lock ALL windows out other than the front D/S because the driver has all controls.
Here is a schematic and LMK if you need anymore
Trebor1964 (04-23-2023)
Old 06-28-2010, 01:37 PM
kx250frider617
So I have to ground out the c2 wire from the driver's door module. Would you know what wire that is? haha. The sad thing is I kind of know what going on in the picture where most people wouldn't have a clue.
Old 06-28-2010, 01:40 PM
kx250frider617
I see its the yellow wire but now I can't tell if its live or a ground.
Old 06-28-2010, 01:43 PM
brettj2408's Avatar
brettj2408
i would assume you would jump tan to yellow to unlock the other windows if it works when you jump it you know its the switch.
Old 06-28-2010, 01:49 PM
kx250frider617
Thanks that makes sense, my plan is to connect the two with one of those splicer things. I don't know what its called so if anyone knows that will help a bunch. And these modules are a rip, $120 for the driver side off lmc truck. Forget that.
Old 06-28-2010, 02:07 PM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
yeah C2 is a yellow 14ga wire. It would have to be a hot wire being that entire module gets fed from the ACC.
Old 06-28-2010, 02:23 PM
kx250frider617
so weed!
Do you agree to splice the yellow with the tan?
That should work if its a Live or not since they eventually get connected by the relay if the module is working right. RIGHT!
With my luck ill open the panel and see 3 yellows and 4 tans.
Quick Reply: wire diagram for driver window switch
